Resetting Catalyst 2926 Series WS-C2926F
Ravi.Kalluri
I need to reset a WS-C2926F back to factory default settings. However I do not have a 25 pin serial cable to connect my system up to the switch. Is there a way for me to do a reset without using telnet?
Thanks.
Ravi
Leo Laohoo
Yes and no.  You can HTML into the appliance if you know the management IP address and the enable password.  Otherwise you need to console into the appliance.
Leo Laohoo
Thank you.
Thanks for the ratings.
