Resillency, system level, network level
carl_townshend
Hi All
when talking about resiliency, can anyone tell me what kind of things would be for network, system and management levels,  ?
cheers
Carl
Ganesh Hariharan
Hi All
cheers
Carl
Hi Carl,
Resiliency form network perspective is to have your production application up and running 24*7,in order to maintain that we used to desgin full redudancy network setup if one goes down the applications will not be affected and from system level means the infrastructre which host the application should also be considered with full reseliancy like dual power supply,dual NIC cards etc.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
can you give me some specific examples of this?
ie, would IP SLA, SNMP be management?
SSO,NSF be a hardware etc ?
