[RESOLVED] Splitting single ISP fiber-connection into multiple routers
kamil.swedrak
[UPDATE]
I was able to resolve this problem with SW L2 switches.
Thanks everyone for helping.
Hello everyone,
I'm struggling with scenario where I need split single WAN connection (6 public addresses available (/29)) between 2 seperate networks.
Wil be enough to simply buy L2 switch and split the connection?
Topology from my side:
ISP
SW L2 ---Fiber optic route ---- SW L2
R1                                                   R2
Thanks for help.
rais
Level 7
Level 7
You may need a fiber splitter:
https://en.wikipedia.org/wiki/Fiber_optic_splitter
HTH.
Collin Clark
It depends. Is your default gateway to the ISP a part of that /29 or is there a separate /30 between you and the ISP and they route the /29 down to you?
Yes - the default GW is a part of /29 and I can use 6 public addresses inside my network.
Good. You can then terminate the connection into a switch and extend that VLAN to any other switch.
