Right way of configuring higher MTU over a Port Channel
Florin Barhala
Level 6
Level 6
Hi guys,
I have a running critical Port-Channel between two locations.
Here's the config
SW1:
interface Port-channel2
 switchport
 switchport mode trunk
end
interface GigabitEthernet1/45
 channel-protocol lacp
 channel-group 2 mode active
end
interface GigabitEthernet1/46
end
SW2
interface GigabitEthernet1/1
 channel-group 2 mode passive
end
interface GigabitEthernet1/2
end
 switchport
end
Now I need to increase the MTU from default value to 9198. What the right way to do it and avoid any connectivity loss, PortChannel restart.
Does it matter what switch I start first?
Thanks!
L.E. both SW are WS-C4948
luckymike33
Because you are using layer 2 interfaces - there is no fragmentation support at layer 2, and interfaces receiving frames which have an unsupported size will be dropped.
I think the best way for you to proceed is to lab this up; and verify what happens - it may be that you need to make changes on switches at either end of the channel within a very short time frame to prevent too large an outage.
 When you are ready to maike your change - think the best way to do this is to use the interface range command, and apply the 'mtu' command to all the interfaces in this range. I don't think it matters which switch you apply this change to first, and I don't believe if you are hinting at the 802.3ad (controlled by system-priority) decision maker, that it makes any difference.
Mike
Hi Mike,
I am planning to change the MTU on the entire path from
Server A - SW1 - SW2-etherchannel-SW3 - SW4 - Server B.
My only concern is if changing MTU on the Etherchannel can affect/disrupt in any way the PortChannel. I can't afford to have it down, not even for 1ms.
I think you will be lucky not to have an outage of even 1ms, like I say I would lab this up, although this is only going to prove the segment between the 2 switches, unless you have 2 identical servers with which you can lab.
It may be better to start asking some questions, like:
What sort of traffic is the network carrying?
Are these links a bottleneck at the moment?
is it possible to add further links into these bundles
How is the load balancing over the links configured? src-mac, src-dst-ip etc
Mike
There is no bottleneck as we speak. I just need to transport some iSCSI traffic and there's the MTU increase requirement.
