RIP configuration not visible on C6509
aklyuka30
HI everyone
i needed to activate RIP 2 on catalist 6509
i'm entering all configuration commands like
conf t
version 2
passive-interface Vlan16
passive-interface GigabitEthernet7/48
passive-interface GigabitEthernet8/44
.passive-interface GigabitEthernet9/45
passive-interface Loopback0
neighbor X.X.X.X
no auto-summary
network X.X.X.X
redistribute eigrp 20
Switch accepts all commands but when i run
"show run" i don't see  any configured command for RIP
Also when i try to run show ip protocols only EIGRP is visiblde - no RIP at all
What's wrong ?
8 Replies 8
andrew.prince
Level 10
Level 10
You need the network statement, otherwise how does the device know which interface to use?
BTW a better way of configuring passive-interfaces is:-
passive-interface default
Then you just need to unpassive the interface you want to use - scales better.
HTH>
I Do have network statement
i entered all networks that i wanted to advertise
network 10.10.11.0
network 192.168.10.0
Network 10.10.12.0
etc ..
passive-interface default - yo are right it's easier to use
anyway queston is not answered yet .. why don't i see configuration onthe switch
why RIP protocol is not activated ?
The question is very much answered.....What type of protocol is RIP - it is a distance vector, what else do we know? it is
a Classfull protocol.
So what is wrong with your config?
network 10.10.11.0
network 10.10.12.0
Hi hari,
Point you have raised is very interesting.
As per orignal post, aklyka is able to observe eigrp details when sh ip protocols is issued but not RIP details.
Is it so that ,if "ip routing" is disabled,still we would see details of "sh ip protocols" command??
Thanks in adv.
Ameya
hariholla
Do you have "ip routing" disabled by chance. I too could not see the RIP configs once "ip routing" was disabled on my 6509 box :-
PE1#show running-config | section router rip
router rip
version 2
network 10.0.0.0
network 192.168.0.0
no auto-summary
PE1#configure terminal
PE1(config)#no ip routing
PE1(config)#
PE1(config)#end
PE1#
*Sep 17 18:20:55.131 IST: %SYS-5-CONFIG_I: Configured from console by console
PE1#
PE1#
ameya_oke
Hi Aklyka,
First enter below commands:
Commands:
router rip
version 2
network 10.10.11.0
network10.10.12.0
Now share output of these commands.
1)show history
2)show running-config
3)show run | b r r
4)sh ip protocols
5)debug ip rip
Andrew as per initial query ripv2 is to be implemented which is classless.
Please rate if helpful.
Ameya
Ameya,
What does the command Version 2 implement? It allows the subnet mask to be sent with the RIP update, which allows classless routing.  HOWEVER the config of the network statements MUST BE CLASSFULL.
So if you configure:-
network 10.10.11.0
network10.10.12.0
The router will not recognise/accept this as they are NOT classfull config statements, for those networks to be recognised they must be changed to:-
network 10.0.0.0
network 192.168.0.0
Why:-
because 10.10.11.0 = class A = 10/8
because 192.168.10.0 = class B = 192.168/16
Helpfull?
Hi Andrew,
Well, I am aware of the fact that network statement must be classful.
But my objection was pertaining to below statement.
Even though the network statement are classful, we can not declare RIP v2 as Classfull routing Protocol and shoud refer it to be a Classless Routing Protocol.
Regret, for my words were misleading.
Anyways , Every reply is helpful and welcomed.
Thanks and Regards
Ameya
