RIP route selection question
dannan lin
Level 3
Level 3
hi:
i am doing experiment with RIP.
the toppology is as follow
The RIP v2 set up was successful however when i try to  trace the packet , i realised the  the router on the right  always send packet via S3/0
why didn't it choose fa1/0 ?
is it some kind of load balance?
thanks in advance.
2 Accepted Solutions
Hi Dannan
RT has two equal cost paths for 1.1.1.1 and hence it has to load-balance but may be seems somewhere my understanding on interpreting the trace ouput is incoherent with the LB. This is a traffic which is originating from the router and not a transit traffic and hence should be process-switched on a round-robin basis.
Can you please try to traceroute multiple times with different source IPs ie once Source as 21.1.1.2 ( take 2 snapshots) and then source as 12.1.1.2 (take two snapshots)  and post the results.
Varma
R       1.1.1.0 [120/1] via 21.1.1.1, 00:00:28, FastEthernet1/0
                [120/1] via 12.1.1.1, 00:00:28, Serial3/0
From here it is clear that the remot n/w is learned by using two interface and it is of same cost. Since it is haveing same cost it will loadbalance with an algorithm called " round robin load balance".
Also RIP can support up to 6 equal path( 4 by default).
Please rate this post if you find this helpful
Vipin
Thanks and Regards, Vipin
7 Replies 7
Vaibhava Varma
Level 9
Level 9
Hi Dannan
This does not seem to be any kind of load-balancing to me personally. Can you please share the output of below command
"sh ip route 1.1.1.1"  and "sh ip rip database "
Varma
vipinrajrc
Level 6
Level 6
it is definetly not a load balace, since RIP is using hop count as metric.
Could you please provide output of "sh ip route"
Vipin
thanks for your reply.
I think it could be load balance as well.  because i ran "trace 1.1.1.1 " command several times ,router choosed different port.
the output looks like below
  1   21.1.1.1        6 msec    3 msec    1 msec
Router#trace 1.1.1.1
Tracing the route to 1.1.1.1
  1   12.1.1.1        10 msec   5 msec    6 msec
  1   21.1.1.1        11 msec   4 msec    4 msec
  1   12.1.1.1        11 msec   6 msec    6 msec
below is the routing table:
     1.0.0.0/24 is subnetted, 1 subnets
     2.0.0.0/24 is subnetted, 1 subnets
C       2.2.2.0 is directly connected, Loopback0
     12.0.0.0/24 is subnetted, 1 subnets
C       12.1.1.0 is directly connected, Serial3/0
     21.0.0.0/24 is subnetted, 1 subnets
C       21.1.1.0 is directly connected, FastEthernet1/0     1.0.0.0/24 is subnetted, 1 subnets
if it is loadbalance ?  what kind of loadbalance is this ? (process based? )
is there any particular rule to choose which port to send packet first?
thanks for your help .
Hi Dannan
Varma
Vipin
thanks guys,
it is a loadbalance , but i still want to know if there is any particular rule to use certain port to send packet first . in my case, why it aways choose 21.1.1.1 ????
below is my trace output :
Router#
  1   21.1.1.1        30 msec   11 msec   1 msec
  1   12.1.1.1        33 msec   5 msec    6 msec
  1   21.1.1.1        25 msec   2 msec    5 msec
  1   12.1.1.1        21 msec   3 msec    3 msec
  1   21.1.1.1        25 msec   5 msec    3 msec
  1   12.1.1.1        24 msec   5 msec    4 msec
thanks.
Hi Danna,
You can use something called PBR(policy based routing) where you can specify which interface the packet should exit from your device using "set-interface " command
please see the below link.
http://www.cisco.com/en/US/docs/ios/12_0/qos/configuration/guide/qcpolicy.html
Kishore
