RIP
jonk34567
Level 4
Level 4
Gateway of last resort is 172.16.14.1 to network 0.0.0.0
R* 0.0.0.0/0 [120/1] via 172.16.14.1, 00:00:20, Ethernet0/2
what command should i enter to have above entry in routing table ?
Francesco Molino
To have this entry in your routing table, you mean have a default route from RIP protocol?
To do that, you need to issue the command default-information originate under your rip protocol configuration
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
