RIPV2 & ACL
fgarakani
I am seeing my default route also being distributed even when I have a ACL specifying only one of my static routes? Why is the default route being distributed? Thanks
Here is main part of the config on router 2:
interface Loopback0
ip address 192.168.40.1 255.255.255.0
interface Serial1/1
no ip address
encapsulation frame-relay
serial restart-delay 0
frame-relay lmi-type ansi
interface Serial1/1.101 point-to-point
ip address 192.168.11.2 255.255.255.0
frame-relay interface-dlci 101
router rip
version 2
redistribute static
passive-interface Loopback0
network 192.168.11.0
network 192.168.40.0
distribute-list 14 out static
no auto-summary
ip route 0.0.0.0 0.0.0.0 192.168.40.2
ip route 10.1.3.0 255.255.255.0 Loopback0
access-list 14 permit 10.1.3.0 0.0.0.255
the routes on Router 1:
Gateway of last resort is 192.168.11.2 to network 0.0.0.0
C 192.168.10.0/24 is directly connected, Loopback0
R 192.168.40.0/24 [120/1] via 192.168.11.2, 00:00:11, Serial1
C 192.168.11.0/24 is directly connected, Serial1/1.101
10.0.0.0/24 is subnetted, 1 subnets
R 10.1.3.0 [120/1] via 192.168.11.2, 00:00:11, Serial1/1.1
C 192.168.1.0/24 is directly connected, FastEthernet0/0
R* 0.0.0.0/0 [120/1] via 192.168.11.2, 00:00:11, Serial1/1.101
R1#sh ip rip da
0.0.0.0/0 auto-summary
0.0.0.0/0
[1] via 192.168.11.2, 00:00:13, Serial1/1.101
10.0.0.0/8 auto-summary
10.1.3.0/24
192.168.1.0/24 auto-summary
192.168.1.0/24 directly connected, FastEthernet0/0
192.168.11.0/24 auto-summary
192.168.11.0/24 directly connected, Serial1/1.101
192.168.40.0/24 auto-summary
192.168.40.0/24
2 Accepted Solutions
mohammedmahmoud
Level 11
Level 11
hi,
Remove the static keyword in the "distribute-list 14 out static" command.
HTH,
Mohammed Mahmoud.
Edison Ortiz
Change
to
distribute-list 14 out Serial1/1.101
Then, clear ip route on R1 and you should have the correct results.
5 Replies 5
mohammedmahmoud
Level 11
Level 11
hi,
HTH,
Mohammed Mahmoud.
Can you tell me what "static" means/does at the end of "distribute-list 14 out static"? I am really puzzled?
Thanks for your help,
Don't be too puzzled, it doesn't work as advertised. It's a bug (CSCds89505). It does not only affects static but other routing protocols such as OSPF, EIGRP and BGP.
Agree with Edison, practically speaking it never works this way.
HTH,
Mohammed Mahmoud.
Edison Ortiz
Change
to
