Route-Map Help
dtom
Level 6
Level 6
Someone before me wrote this route-map and I am trying to see if I can figure out what they are doing here (see below):
Interface Gig1/0/0
  ip address 10.0.1.254 255.255.255.0
  ip policy route-map FILTER
route-map FILTER permit 10
  match ip address 43
route-mape FILTER permit 11
  match ip address 45
route-map FILTER permit 12
  match ip address 51
  set ip next-hop 10.223.250.133
route-map FILTER permit 13
  match ip address 55
  set ip next-hope 10.223.8.150
access-list 43 permit 10.223.241.108
access-list 43 permit 172.30.231.31
ip access-list standard 45
  permit 172.26.65.253
  permit 172.18.150.36
  permit 10.223.248.63
access-list 51 permit 10.113.48.1
ip acces-list extended 55
  deny tcp any 172.16..0 0.15.255.255 eq www 443 8080
  deny tcp any 10.0.0.0 0.255.255.255 eq www 443
  permit tcp any any eq www 443
So, here is how I see it working...
1) Traffic comes into Gig1/0/0
2) The traffic is check via route-map FILTER
3) If the IP address matches access-list 43 it is allowed through (no further evaluation)
4) If the IP address matches access-list 45 it is allowed through (no further evaluation)
5) If the Ip address matches access-list 51 the next hop will be set to 10.223.250.133 and it is allowed through (no further evaluation)
6) If the Ip address matches access-list 55 the next hop is set to 10.223.8.150 and it is allowed through (no further evaluation
7) No matches, it is not allowed through (or is)?
Am I on the right track here?
Hello
route maps instances are checked sequentially - meaning any traffic not matched in instance 10 would be then checked in the instance 11 ,12 so on so on...
If there is no match found then traffic is routed normally.
Res
Paul
Kind Regards
Paul
9 Replies 9
Giuseppe Larosa
Hello Dtom,
this is an example of Policy Based Routing, traffic flows not matching any route-map clause will be routed using standard destination based routing = using the IP routing table. They will not be dropped as this is not an ACL applied inbound.
see
http://www.cisco.com/en/US/tech/tk364/technologies_configuration_example09186a00802135d3.shtml
There is no filtering action the route-map name is clearly misleading.
Hope to help
Giuseppe
Hello Giuseppe
What about if the next hop is unavailable? Without any verification wouldn't the router just keep on trying to PBR to these next hop addresses thus causing unwarranted arps?
Res
Paul
Kind Regards
Paul
Hello Paul,
if next-hop is not available and the device is not able to detect it and it has still information to perform packet rewrite traffic will be sent out with a destination MAC address that is not reachable anymore
When the ARP entry will expire the device will try to resolve again the next-hop and this time the device understands next-hop is not available anymore.
So the big issue here without next-hop verification methods, is traffic blackholing, the ARP activity when it will happen is the only fix available to the device
Manual clear of ARP table may be the first option in a case like this.
Modern IOS and platforms allows for neighbor validation in different ways and you are right if available these methods should be used.
Hope to help
Giuseppe
Hello Giuseppe
Thanks for the "verification" - lol
Res
Paul
Kind Regards
Paul
So in this example, if the traffic matches the first route-map (route-map FILTER permit 10) then the traffic will be routed using the standard destination based routing using the IP routing table otherwise the traffic will go on to the next route-map (route-map FILTER permit 11).  Am I correct here?
Hello
Res
Paul
Kind Regards
Paul
So in the example below, if it matches instance 10 --> access-list 43 --> 10.223.241.108, checking will stop and the traffic will just be allowed through (with no next-hop changes).  Am I correct here?
Interface Gig1/0/0
match ip address 43
match ip address 45
match ip address 51
Hello, just to go back to your original post.... and to explain what this configuration is doing... (please correct me if im wrong)
Interface Gig1/0/0
This is a policy applied on an interface - PBR policy based routing as mentioned already
Policy is defined by the route-map FILTER
  match ip address 43
Entry 10 is matching access list 43, but has no action set - no action taken and traffic is
processed as normal
  match ip address 45
Entry 11 is matching access list 45, but has no action set - no action taken and traffic is
processed as normal
  match ip address 51
Entry 12 is matching access list 51, so anything that matches ip address 10.113.48.1
its next hop will be set to 10.223.250.133
  match ip address 55
  set ip next-hop 10.223.8.150
Entry 13 is matching access list extended access list which is a bit more complex
Please bare in mind that this is for policy based routing, not ACL permit deny as such
'Deny' means - do not perform policy based routing on this type of traffic
'Permit' means- perform policy based routing on this type of traffic:
  1. deny any traffic from the 172.16.0.0 RFC 1918 range that is eq to www 443 8080 - do NOT perfom PBR
  2. deny any traffic from the 10.0.0.0 RFC 1918 range that is eq to www 443 - do NOT perform PBR
  3. permit any TCP traffic from any address that equals www and 443 - Perform PBR
Set the next hop to be 10.223.8.150
ANY OTHER TRAFFIC WILL BE TREATED NORMALLY
  deny tcp any 172.16.0.0 0.15.255.255 eq www 443 8080
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Hello
Yes that is correct without a set statement, it will act upon the acl, meaing in this config it simply permit traffic sourced from access-list 43 45 routed normally.
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
