Route-Map Question
Rawa Salah
Hello
please I have 2 CacheServer in my Network , and 2 Range of IPs , i want to route the first range to CacheServer1 and Second range to the CacheServer 2
, can i make 2 Route-Map for both of them , find the configuraition bellow if its true or not ? please help my Urgent Case
CacheServer 1 IP address : 10.10.1.1
CacheServer 2 IP address: 10.10.2.1
ip access-list extended AA
permit tcp 192.168.1.0 0.0.0.255 any eq www
ip access-list extended AB
permit tcp any eq www 192.168.1.0 0.0.0.255
ip access-list extended BB
permit tcp 192.168.2.0 0.0.0.255  any eq www
ip access-list extended BC
permit tcp any eq www 192.168.2.0 0.0.0.255
route-map TEST1
match ip address AA
set ip next-hope 10.10.1.1
match ip address BB
set ip next-hope 10.10.2.1
route-map TEST2
match ip address AB
match ip address BC
Interface gig 0/1
ip policy route-map TEST1
Interface gig 0/2
ip policy route-map TEST2
is it clear please ????????? MY question is , can i put two "match" and "set" command  in one route-map ?????
John Blakley
I had originally responded, but then reread your question. I noticed that you expect to see two different networks on the same interface, so for g0/1 you could see aa OR bb.
The easiest way I can think of is a route map like the following:
route-map Test1 permit 10
match ip address AA
set ip next-hop 10.10.1.1
route-map Test1 permit 20
match ip address BB
set ip next-hop 10.10.2.1
int g0/1
ip policy route-map Test1
route-map Test2 permit 10
match ip address AB
route-map Test2 permit 20
match ip address BC
int g0/2
ip policy route-map Test2
So, yes, you can have multiple match and set statements in the same route-map, but you'll need to separate them by multiple clauses.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
John Blakley
match ip address AA
match ip address BB
int g0/1
match ip address AB
match ip address BC
int g0/2
HTH,
John
Thank you Mr. John .... Appreciated
i guess ur answer is perfect and its helpful for me ,Thank you again
