Router 7613 boot problem
Hi guys, I have a router 7613 with a supervisor 720. each time I reboot it I have the follow:
*** --- SHUTDOWN NOW ---
Mar 24 09:55:16: %SYS-SP-5-RELOAD: Reload requested
Mar 24 09:55:16: %OIR-SP-6-CONSOLE: Changing console ownership to switch process
or
Mar 24 09:55:16: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ens
ure console debugging output.
System Bootstrap, Version 8.4(2) Release
Copyright (c) 1994-2005 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 1048576 Kbytes of main memory
rommon 1 >
I am using only one supervisor the standby blade is not inserted.
the onfiguration register is 0x2102
What the problem could will be?
Thanks!
a.alekseev
Level 7
Level 7
in rommon set correct BOOT variable
after that enter command "sync"
It should fix your problem.
Hi this is what I have:
router#show bootvar
BOOT variable = ,1;sup-bootdisk:s72033-advipservicesk9_wan-mz.122-18.SXF15a.bin,
1;
CONFIG_FILE variable =
BOOTLDR variable =
Standby is not present.
rommon 1 > set
PS1=rommon ! >
LOG_PREFIX_VERSION=1
CONFIG_FILE=bootflash:switch.cfg
?=0
BOOT=bootdisk:,1;
SLOTCACHE=cards 1=104(241@3,241@300),2=104(41@FF,41@FF00),3=104(167@1,167@100),4
=104(1E7@1,-);
CRASHINFO=bootflash:crashinfo_20090227-190703
TYFIB_BLOCK_ALLOC=
BSI=0
ACL_DENY=0
PF_REDUN_CRASH_COUNT=0
How can I fix it? can yo give a example please?
Thnks
It looks like you have an extra BOOT variable " ,1".
try to remove all boot statement in your current config and then add the one you need back. After that, check the output of "show bootvar".
in rommon do the following
BOOT=sup-bootdisk:s72033-advipservicesk9_wan-mz.122-18.SXF15a.bin
sync
and check "boot system" in the configuration
