router and layer 2 switch, etherchannel
sarahr202
Level 5
Level 5
Hi everybody
Please consider the following scenario
  internet------  Router f0/0------------------------------f1/1SW-----------rest of network
                                f0/1-------------------------------f1/2
hosts located in " rest of network" uses Router as a default gateway to reach internet.  Sw is a layer 2 switch. We want to establish a etherchannel between routers routed ports f0/0,f0/1 and sw acess ports f1/1,f1/2. So our etherchannel will have l3 ports on one side( at router) and l2 accessports at sw side.
We want to use PagP to form etherchannel.
I configured sw for etherchannel as:
int range f1/1-2
switchport access vlan 1
channel-protocol  PagP   ( do i need this command ? )
channel-group 1 mode desirable.
Now how do we configure router for etherchannel? the port channel should be configured with ip 199.199.199.1/24 which is the default gateway for hosts located in " rest of network".
thanks and have a great weekend.
Hi Sara,
i found a better example/template for you
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_example09186a00800ef797.shtml
Have a great week end you too
Alessio
Thanks Alessio
