Router continually logging interface as "up"
clark-computers
I've got a really strange problem on an 1841. It is running IOS 12.4(24)T1 and is configured with Fa0/0 in the internal network and two ADSL cards connected to ADSL lines.
When I was looking through the logs, the fa0/0 interface logs several "changed state to up" logs, but without any preceeding "changed state to down" logs (see attached).
Why is this and should I be concerned by it?
Giuseppe Larosa
Hello Andrew,
similat issues have been seen in other threads in last mounths.
if you don't see real problems this could be just an annoying bug filling your log buffer and syslog servers.
log messages show one message per minute.
You should be fine.
Hope to help
Giuseppe
Giuseppe
Thanks for the note.
There aren't any really big issues, but the client occasionally sees this router dropping off the network (they have an SNMP monitor at the central office and this router is the VPN gateway at a remote site), although the VPN never actually goes down and traffic still traverses the VPN.
I suspect that, quite simply, the timers have exceeded when the VPN is heavy with traffic because the SNMP packets aren't getting through.
Anyways, thanks for the help.
