router dhcp problem
Jangelides
Hi guys, currently learning CCNA. Stuck with a small probem. I have a 1760 Router that I have configured as a DHCP server to the VLAN's on my switch. I have followed all the instructions that I have found but unfortunately the switch is just not getting assigned the ip addresses.  Can anyone help me please.
Here is my router config
Current configuration : 6971 bytes
version 12.4
hostname SunrayR
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.20.1
ip dhcp excluded-address 192.168.30.1
ip dhcp pool LAN10
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
ip dhcp pool LAN20
   network 192.168.20.0 255.255.255.0
   default-router 192.168.20.1
ip dhcp pool LAN30
   network 192.168.30.0 255.255.255.0
   default-router 192.168.30.1
interface FastEthernet0/0
 no ip address
 speed 100
 full-duplex
interface FastEthernet0/0.10
 encapsulation dot1Q 10
 ip address 192.168.10.1 255.255.255.0
 no snmp trap link-status
interface FastEthernet0/0.20
 encapsulation dot1Q 20
 ip address 192.168.20.1 255.255.255.0
interface FastEthernet0/0.30
 encapsulation dot1Q 30
 ip address 192.168.30.1 255.255.255.0
interface Serial0/0
 no ip address
 shutdown
interface Ethernet1/0
 no ip address
 shutdown
 half-duplex
no ip http server
no ip http secure-server
control-plane
line con 0
 exec-timeout 0 0
 password ********
 logging synchronous
 login
line aux 0
line vty 0 4
 exec-timeout 0 0
 password ********
 logging synchronous
 login
 transport input ssh
line vty 5 15
 exec-timeout 0 0
 password ********
 logging synchronous
 login
 transport input ssh
end
Special thanks in advance.
21 Replies 21
Again thank you so much.  Would have taken me forever to spot that.  Hopefully.....on day.......i get to be half as good as some of guys on here. One hurdle complete 1001 lef to go.
Port 1 in my switch which is in native vlan 1 is connected to fa0/0 on the router.
Not sure what you mean by this ie. the port should be configured as a trunk.
Which specific port on the switch connects to the router ?
Also which port is the client connected to ?
Jon
Sorry my mistake. fa0/1 on the switch is configured as a dot1q trunk and connected to fa0/0 on the router.  The client pc is connected to fa0/2 on the switch which is configured as an access port and in vlan10.
I just checked your switch configuration. you need to assign an IP address to each SVIs. Assign .2 IP address on each SVI.
ROUTER <----> SWITCH
Router will be tagging VLAN 10,20,30 traffic and using .1 IP address
Your switch also needs to tag the traffic and send it to Router using SVIs.
Also, do not use 'ip default-gateway' -> this is for L2 switch
Use 'ip route 0.0.0.0 0.0.0.0 next-hop' for L3 switches
G1
The router is doing the inter vlan routing not the switch so -
1) the SVIs should be left shutdown and do not need IP addresses
2) you should use "ip default-gateway" because the switch is acting as a L2 switch and not L3
Jon
I realised that and removed the IP helper-address commands. I did set the default gateway to 192.168.1.1 which is the IP address of fa0/0.1 on the router.
My equipment consists of a cisco 1760 router and a cisco layer '2' switch, so svi's are not an option.
