Router not routing
I purchased this used a couple weeks ago, and have trolled all the forums I can find.  I have this router connected to my home internet 192.168.1.254 on FastEthernet0/0.  Then connected to a laptop on FastEthernet0/1.  (I have a switch but I took it out of the loop for troubleshooting) It assigns DHCP as expected, but I'm unable to ping from the laptop to the service provider.  192.168.1.254.  One of the tips I found here was to do a extended ping from the inside interface, I did that, and it failed as well, but I'm not finding out why.  Any help fixing it is appreciated, and any help showing me how to fix it myself is GREATLY appreciated.
Building configuration...
Current configuration : 4023 bytes
version 12.4
hostname router
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $1$VAnI$wQsHGam9zGVrQPyzcfXTd0
enable password
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.24.1.1
ip dhcp excluded-address 10.24.1.2
ip dhcp excluded-address 10.24.1.3
ip dhcp pool NET-POOL
network 10.24.1.0 255.255.255.0
default-router 10.24.1.1
domain-name test.com
dns-server 8.8.8.8 8.8.4.4
lease infinite
no ip domain lookup
ip domain name test.com
ip name-server 8.8.8.8
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
voice-card 0
username admin password 0
ip ssh version 2
interface FastEthernet0/0
description "LINK TO ROUTER"
ip address 192.168.1.253 255.255.255.0
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description "LINK TO SWITCH"
ip address 10.24.1.1 255.255.255.0
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.254
no ip http server
no ip http secure-server
control-plane
mgcp behavior g729-variants static-pt
alias exec c configure terminal
alias exec s show ip interface brief
alias exec sr show running-config
alias exec qs copy running-config startup-config
line con 0
password
login
line aux 0
line vty 0 4
exec-timeout 10 30
password
logging synchronous
login local
history size 15
transport input telnet ssh
scheduler allocate 20000 1000
end
router#
What type/brand/model is the ISP modem/router ?
Either way, the NAT part of your config is fairly easy. I highlighted what you need to add to get your clients out to the Internet. Provided, of course, that the ISP modem/router has a route back to 10.24.1.0/24...
version 12.4
hostname router
boot-start-marker
boot-end-marker
no logging console
enable password
no aaa new-model
ip cef
lease infinite
no ip domain lookup
voice-card 0
ip ssh version 2
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
ip nat inside source list 1 interface FastEhernet0/0 overload
access-list 1 permit 10.24.1.0 0.0.0.255
no ip http server
control-plane
line con 0
password
login
line aux 0
line vty 0 4
exec-timeout 10 30
password
logging synchronous
login local
history size 15
end
6 Replies 6
ss1
I apologize if there's something that I can't understand there but how does your internet router 192.168.1.254 know about 10.24.1.0/24? I believe you have to log into your Provider CPE 192.168.1.254 and create a routing for 10.24.1.0/24 via 192.168.1.253. Also I believe that some of the routers must NAT 10.24.1.0/24 behind itself. Either must your have your new Cisco perform NAT of 10.24.1.0/24 and send the traffic to the Provider CPE sourced as 192.168.1.253, OR you must NAT 10.24.1.0/24 within the Provider CPE and create a routing for that network as well.
I hope I understood the topology clearly and there's nothing I missed. Sorry if not so.
Thank you.
do you have physical connectivity at all between the devices ? You probably need a crossover cable. By default, when you ping 192.168.1.254, interface FastEthernet0/0 is used as the source, so if the ping fails, I would check for physical (cabling) problems first...
Great advice.  Thank you both.  First question how does "internet router" know about 10.24.1.1? short answer is it doesn't.  I'm not to the point yet of accepting traffic from the internet as that scares me.  I think you are on to something with NAT though.  I'm reading up on that now.  I had asked my I.T. guy at work (This is a personal project) to look over my config last week and was told that the internet router would be doing NAT, but I'm beginning to suspect that there was a miss communications between us somewhere.
As for physical connectivity, I'm able to ping from 192.168.1.253 to 254.  but not from 10.24.1.1  Physical connectivity is what I do for work, so it was my first troubleshooting step as well.  Sorry, I should have said up top.
Good point which I seem to have overlooked when commenting.
A possible issue might be a static mac address on the Provider CPE. The service Provider might need to be contacted in order to remedy this.
version 12.4
hostname router
boot-start-marker
boot-end-marker
no logging console
enable password
no aaa new-model
ip cef
lease infinite
no ip domain lookup
voice-card 0
ip ssh version 2
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
no ip http server
control-plane
line con 0
password
login
line aux 0
line vty 0 4
exec-timeout 10 30
password
logging synchronous
login local
history size 15
end
It's up and running.  I had gotten so close.  from searching around the internet I had access-list 1 permit 192.168.1.0 0.0.0.255.  I see now why I had it backwards.  Thank you again.
