Router on a stick with NAT problems.
Brian Wcisel
Greetings community,
I am having trouble getting my cable modem, 2801, and 3550 to play nice together.
SOHO Comcast cable modem set in bridge mode --> Cisco 2801  -->  Cisco 3550
I am using my router as both the gateway for my home lan and a gateway for my Unified Communications Manager setup, also running on this network.
Issue:  I have two VLANS on the network, one for data(vlan 50) and the other for voice(vlan 10), routed through 2 sub-interfaces(FA0/1.1 and FA0/1.2)  Interface FA0/0 is connected to my cable modem and has no problem pulling DHCP [See example one].  Pings to the internet from the router work fine.
Example one
#show ip dhcp lease
Temp IP addr: 66.41.95.20  for peer on Interface: FastEthernet0/0
Temp  sub net mask: 255.255.255.0
   DHCP Lease server: 68.87.77.10, state: 5 Bound
   DHCP transaction id: 2429
   Lease: 345600 secs,  Renewal: 172800 secs,  Rebind: 302400 secs
Temp default-gateway addr: 66.41.95.1
   Next timer fires after: 1d23h
   Retry count: 0   Client-ID: cisco-0018.ba12.b7c0-Fa0/0
   Client-ID hex dump: 636973636F2D30
Two DHCP Scopes 192.168.3.0/24(data vlan) and 192.168.4.0/24(voice vlan) include the import all command to pass DNS from ISP through to clients via DHCP lease.
NAT
Two access lists for the 3.x and 4.x subnets
fa0/0 has nat outside and fa0/1 has nat inside.
With the current config, both vlans hand out ip addresses, but NOT public DNS information.  I can ping around inside the network, but can't get DNS to work.  (This works when subinterfaces are not involved.)
Am I doing something fundementally wrong ?  Is there another way to approach Nat and public(DHCP) dns distribution besides the method I have used?
Any help is appreciated.  This works fine without subinterfaces using only one VLAN and one internal LAN interface(Fa0/1 instead of subints fa0/1.1 and fa0/1.2)
and yes, all interfaces involved have been checked and are NOT shutdown(including the sub-int's)
Bottom line:  I just want my cable modem, router, switch, and lan to play nice together.
Thanks in advance if anyone see's anything obvious or can help.
You will find the router and switch configs attatched.
-Brian W
Router config followed by Switch config
hostname home_router
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/1
no aaa new-model
dot11 syslog
ip source-route
no ip dhcp conflict logging
ip dhcp excluded-address 192.168.3.1 192.168.3.10
ip dhcp excluded-address 192.168.4.1 192.168.4.10
ip dhcp pool home_data_scope
   import all (<-----  This is the command to pass dhcp options through to internal DHCP clients along with their IP info)
   network 192.168.3.0 255.255.255.0
   default-router 192.168.3.1
   option 150 ip 192.168.3.150
ip dhcp pool home_voip_scope
   network 192.168.4.0 255.255.255.0
   default-router 192.168.4.1
ip cef
no ipv6 cef
voice-card 0
license udi pid CISCO2801 sn FTX1036Z04L
username cisco privilege 15 secret 5 $1$tyIO$gT6FlfQsaCU5TTGx1cxG80
interface FastEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface FastEthernet0/1
no ip address
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1.1
description Home Data Vlan
encapsulation dot1Q 50 (<------- Adding "native" to this command((as recommended by cisco)) kills my DHCP reachablility, not certain why)
ip address 192.168.3.1 255.255.255.0
interface FastEthernet0/1.2
description Home Voice VLAN
encapsulation dot1Q 10
ip address 192.168.4.1 255.255.255.0
interface Serial0/3/0
no ip address
shutdown
no fair-queue
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/0 overload (<----NAT)
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
logging esm config
access-list 1 permit 192.168.3.0 0.0.0.255 (<----NAT)
access-list 1 permit 192.168.4.0 0.0.0.255 (<----NAT)
snmp-server community public RO
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
line con 0
logging synchronous
login local
line aux 0
line vty 0 4
logging synchronous
login local
transport input all
---------------------------------------------SWITCH CONFIG------------------------------------------
Home_Switch02#show run
Building configuration...
Current configuration : 5686 bytes
version 12.2
no service pad
hostname Home_Switch02
enable secret 5 $1$Jfeq$d0YW9khJCnz98DUAdBIRm/
no aaa new-model
ip subnet-zero
crypto pki trustpoint TP-self-signed-3976201216
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3976201216
revocation-check none
rsakeypair TP-self-signed-3976201216
crypto pki certificate chain TP-self-signed-3976201216
certificate self-signed 01
  30820246 308201AF A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33393736 32303132 3136301E 170D3933 30333031 30303030
  35395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 39373632
  30313231 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B569 93A35078 D47296AB 6B947E6D B203BB56 75731A41 E821C905 8D05FF27
  DF3CB88E 30337635 E0F1C8FD DC5DB79A 0D9FF48F 4E277DC4 77E85BBA 1D8F116C
  9013D45B E492889B 721DCCF9 F4AE21D4 661D8590 448F7BAF FA1C6FE7 9D23D87F
  08833CD8 DE68298A 733EBD0D E2057D65 204F6265 8AB5A3AC 6C2756A0 3EE4A91E
  4B490203 010001A3 6E306C30 0F060355 1D130101 FF040530 030101FF 30190603
  551D1104 12301082 0E486F6D 655F5377 69746368 30322E30 1F060355 1D230418
  30168014 06989916 3158CD67 1A5D1704 CBA1B0D0 F651DA71 301D0603 551D0E04
  16041406 98991631 58CD671A 5D1704CB A1B0D0F6 51DA7130 0D06092A 864886F7
  0D010104 05000381 8100196E A8593CB6 81EA9222 C61C654C 6AFE3E2D 44CAC483
  6E72BF18 BD275E10 C385DC45 996E34EF 9B162A53 FD254959 4C76D110 430E57AE
  6E823C61 302A463B 58561DE4 2029737D 8024EC2A 6CC757C8 442C9AFD D63632A3
  B7730549 E457CE98 A8FDB381 EB1933AB 567A8752 00FCC45C 7B14038D 2D94C4A6
  70DE679E 0318D92B A397
  quit
spanning-tree mode pvst
vlan internal allocation policy ascending
switchport access vlan 50
switchport mode access
switchport voice vlan 10
spanning-tree portfast
**************omited**************
interface FastEthernet0/24
description Uplink to Home_Switch01
switchport mode trunk
((Do I need to add the allowed vlans command here?  So far it has not made a difference during my troubleshooting))
interface GigabitEthernet0/1
interface GigabitEthernet0/2
switchport mode dynamic desirable
interface Vlan1
no ip address
interface Vlan20
no ip address
interface Vlan50
ip address 192.168.3.202 255.255.255.0
ip classless
ip http server
control-plane
line con 0
password cisco
logging synchronous
login
line vty 0 4
password cisco
logging synchronous
login
line vty 5 15
password cisco
logging synchronous
login
end
lgijssel
Level 9
Level 9
To include dns in the requests for inbound clients, you should rather hardcode the dns addresses in the scope definition.
The -import all- parameter should only be used on the ISP-side.
You do not need the command to allow all vlans. By default, all vlans are allowed.
regards,
Leo
I figured it out.  I needed to remove the ip nat inside command from the fa0/1 interface and instead, have it on each sub-interface.
Thank's for the suggestion!
