Router or Switch logs will not show port-security trigger events.
CiscoBrownBelt
Level 6
Level 6
When I do show log, port-security events are not shown here. How do I show  all events like this in the logs. I basically want to be able to issue "show log" and see any ports that go up/down, port-secrutiy err disabled, etc.?
Try this "logging buffered 10000 debugging"
-If I helped you somehow, please, rate it as useful.-
You might try logging event link-status and see if that helps.
Rick
Rick
OK I will do that. When I issue "show run all", I have a "logging cns-events informational"
