Router to Switch Connectivity
vishal-patil
I am trying to connect switch (loaded ios 3725 in GNS3) to two routers.
I have configured both interfaces fa0/0 and fa0/1. I also disabled ip routing on SW
But somehow I cannot ping R2 from R3 and vice versa.
Am I missing something?
Please see attached topology
Vish
7 Replies 7
please share configurations of SW,R2 and R3
thanks
R2#sh run
Building configuration...
Current configuration : 1333 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
archive
 log config
  hidekeys
ip tcp synwait-time 5
interface Loopback0
 ip address 178.8.3.3 255.255.255.0
interface FastEthernet0/0
 no ip address
 shutdown
 duplex auto
 speed auto
interface Serial0/0
 ip address 178.8.1.2 255.255.255.0
 clock rate 2000000
interface FastEthernet0/1
 ip address 178.8.2.2 255.255.255.0
 duplex auto
 speed auto
interface Serial1/0
 no ip address
 shutdown
 serial restart-delay 0
interface Serial1/1
 no ip address
 shutdown
interface Serial1/2
 no ip address
 shutdown
interface Serial1/3
 no ip address
 shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
no cdp log mismatch duplex
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
end
_____________________________________________________________________________
SW#sho running-config
Current configuration : 1549 bytes
version 12.4
hostname SW
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip routing
no ip cef
no ip domain lookup
archive
 log config
  hidekeys
 no ip address
 no ip route-cache
 shutdown
 duplex auto
 speed auto
interface Serial0/0
 no ip address
 no ip route-cache
 shutdown
 clock rate 2000000
 no ip address
 no ip route-cache
 shutdown
 duplex auto
 speed auto
interface FastEthernet1/0
interface FastEthernet1/1
interface FastEthernet1/2
interface FastEthernet1/3
interface FastEthernet1/4
interface FastEthernet1/5
interface FastEthernet1/6
interface FastEthernet1/7
interface FastEthernet1/8
interface FastEthernet1/9
interface FastEthernet1/10
interface FastEthernet1/11
interface FastEthernet1/12
interface FastEthernet1/13
interface FastEthernet1/14
interface FastEthernet1/15
interface Vlan1
 no ip address
 no ip route-cache
no ip http server
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
end
R3#sho run
Current configuration : 1540 bytes
version 12.4
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
archive
 log config
  hidekeys
interface Tunnel0
 ip address 10.0.12.2 255.255.255.0
 tunnel source 178.8.2.1
 tunnel destination 178.8.1.1
 ip address 178.8.2.1 255.255.255.0
 duplex auto
 speed auto
interface Serial0/0
 no ip address
 shutdown
 clock rate 2000000
 ip address 10.0.3.1 255.255.255.0
 duplex auto
 speed auto
interface Serial1/0
 no ip address
 shutdown
interface Serial1/1
 no ip address
 shutdown
interface Serial1/2
 no ip address
 shutdown
interface Serial1/3
 no ip address
 shutdown
router eigrp 10
 network 10.0.2.0 0.0.0.255
 network 10.0.3.0 0.0.0.255
 network 10.0.12.0 0.0.0.255
 no auto-summary
ip route 0.0.0.0 0.0.0.0 178.8.2.2
no ip http server
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
end
Your configuration on interfaces seems to be correct. When you are using 16ESW on router, it is easy to mess up the link numbers for connection.
Go on the router which you are using as a switch and check the output of this command.
Show cdp neighbor detail.
Check the connection(fa0/1 to fa1/0 as an example) and also IP addresses. On your switch, you should see both routers IPs with this command.
If the connections are correct, remove your tunnel interface and also route commands  and try again.
If you are not successful again, change the IOS of your SW.
For switch configuration, packet tracer is more suggested. It is free to download.
Hope it helps,
Masoud
Hello Vish,
In GNS these switches are layer 2 switches, Try assigning a common vlan tag on switch for both the ports connecting router and then check is it pinging or not.
Hope it Helps..
-GI
I don't see any routing on R2
you have router eigrp 10 on R3, need to configure the same on R2
Hi Richard,
Actually I am configuring GRE tunnel with IPSec
When i checked today, it was working. But thank you for your help
Must the no ip routing command on sw. Somehow it was not working when configured for the first time
Hi Vishal,
You have a static route ip route 0.0.0.0 0.0.0.0 178.8.2.2 from the router R3 but no static route observed over the Router R2 .. Configure static ip route over the Router R2 as:
ip route 0.0.0.0 0.0.0.0 178.8.2.1
once done.. try to reach R3 from R2 and vice versa
