06-24-2015 07:04 AM - edited 03-08-2019 12:41 AM
Hello guys.
In the attachment there is a topology with RIP on the one side and OSPF on another side.
When I'm trying to redistribute routes from RIP to OSPF using prefix lists it works fine.
R2(config)#ip prefix-list RIP_OSPF permit 172.16.0.0/16 le 24
R2(config)#route-map RIP_OSPF permit 10
R2(config-route-map)#match ip address prefix-list RIP_OSPF
R2(config-route-map)#exit
R2(config)#router ospf 1
R2(config-router)#redistribute rip metric 100 subnets route-map RIP_OSPF
However, when I'm trying to use prefix list to redistribute routes from OSPF to RIP using prefix lists it doesn't work.
R2(config)#ip prefix-list OSPF_RIP permit 192.168.0.0/16 le 24
R2(config)#route-map OSPF_RIP permit 10
R2(config-route-map)#match ip address prefix-list OSPF_RIP
R2(config-router)#redistribute ospf 1 metric 2 route-map OSPF_RIP
Why prefix lists work for redistribution from RIP to OSPF but doesn't for redistribution from OSPF to RIP.
Just for any case below are full configs from all three routers.
R1#sh run
interface Loopback0
ip address 172.16.0.1 255.255.255.0
interface Loopback1
ip address 172.16.1.1 255.255.255.0
interface Loopback2
ip address 172.16.2.1 255.255.255.0
interface Loopback3
ip address 172.16.3.1 255.255.255.128
interface Loopback4
ip address 172.16.3.129 255.255.255.128
interface Loopback5
ip address 172.16.4.1 255.255.255.128
interface Loopback6
ip address 172.16.4.129 255.255.255.128
interface Serial1/0
ip address 10.1.12.1 255.255.255.252[/CODE]
R2#sh run
interface Serial1/0
ip address 10.1.12.2 255.255.255.252
interface Serial1/1
ip address 10.1.23.1 255.255.255.252
router ospf 1
router-id 2.2.2.2
log-adjacency-changes
redistribute rip metric 100 metric-type 1 subnets route-map RIP_OSPF
network 10.1.23.0 0.0.0.3 area 0
router rip
version 2
network 10.0.0.0
no auto-summary
ip prefix-list OSPF_RIP seq 5 permit 192.168.0.0/16 le 24
ip prefix-list RIP_OSPF seq 5 permit 172.16.0.0/16 le 24
route-map OPSF_RIP permit 10
R3#sh run
interface Loopback0
ip address 192.168.0.1 255.255.255.0
ip ospf network point-to-point
interface Loopback1
interface Loopback2
ip address 192.168.2.1 255.255.255.0
interface Loopback3
ip address 192.168.3.1 255.255.255.128
interface Loopback4
ip address 192.168.3.129 255.255.255.128
interface Loopback5
ip address 192.168.4.1 255.255.255.128
interface Loopback6
ip address 192.168.4.129 255.255.255.128
interface Serial1/1
ip address 10.1.23.2 255.255.255.252
router ospf 1
router-id 3.3.3.3
network 0.0.0.0 255.255.255.255 area 0
06-25-2015 04:41 AM
Am I correct that you are expecting R2 to have RIP routes for 172.16.0.0, 172.16.1.0, and 172.16.2.0 and to redistribute them? I believe that what is happening is that R1 running RIP is doing automatic summarization and is advertising 172.16.0.0/16.
Rick
06-25-2015 06:16 AM
The thing is that I tried to redistribute OSPF routes into RIP under OSPF configuration.
06-28-2015 05:36 AM
Hello guys.
Another one question about routes redistribution but with the other topology. Below the configs from all 6 routers:
R1#sh run
router ospf 1
router-id 1.1.1.1
redistribute rip metric 10 metric-type 1 subnets route-map RIP_TO_OSPF
network 10.1.12.1 0.0.0.0 area 0
network 10.1.13.1 0.0.0.0 area 0
router rip
version 2
redistribute ospf 1 metric 5 route-map OSPF_TO_RIP
network 10.0.0.0
network 172.16.0.0
no auto-summary
ip prefix-list OSPF_TO_RIP seq 5 permit 192.168.0.0/16 ge 24
ip prefix-list OSPF_TO_RIP seq 10 permit 10.1.12.0/30
ip prefix-list OSPF_TO_RIP seq 15 permit 10.1.13.0/30
ip prefix-list OSPF_TO_RIP seq 20 permit 10.1.24.0/30
ip prefix-list OSPF_TO_RIP seq 25 permit 10.1.34.0/30
ip prefix-list RIP_TO_OSPF seq 5 permit 172.16.0.0/16 ge 24
ip prefix-list RIP_TO_OSPF seq 10 permit 10.1.15.0/30
ip prefix-list RIP_TO_OSPF seq 15 permit 10.1.26.0/30
ip prefix-list RIP_TO_OSPF seq 20 permit 10.1.56.0/30
route-map OSPF_TO_RIP permit 10
match ip address prefix-list OSPF_TO_RIP
route-map RIP_TO_OSPF permit 10
match ip address prefix-list RIP_TO_OSPF
R2#sh run
router ospf 1
router-id 2.2.2.2
network 10.1.12.2 0.0.0.0 area 0
network 10.1.24.1 0.0.0.0 area 0
router rip
version 2
network 10.0.0.0
network 172.16.0.0
no auto-summary
R5#sh run
router rip
version 2
network 10.0.0.0
network 172.16.0.0
no auto-summary
R6#sh run
router rip
version 2
network 10.0.0.0
network 172.16.0.0
no auto-summary
R3#sh run
router ospf 1
router-id 3.3.3.3
network 10.1.13.2 0.0.0.0 area 0
network 10.1.34.1 0.0.0.0 area 0
network 192.168.3.0 0.0.0.255 area 0
R4#sh run
router ospf 1
router-id 4.4.4.4
network 10.1.24.2 0.0.0.0 area 0
network 10.1.34.2 0.0.0.0 area 0
1. Why R2 learns about subnets 10.1.56.0/30, 172.16.5.0/24 and 172.16.6.0/24 via RIP, but R1 learns about the same subnets via OSPF?
R1#sh ip route ospf
172.16.0.0/24 is subnetted, 4 subnets
O E1 172.16.5.0 [110/11] via 10.1.12.2, 00:15:54, FastEthernet0/1
O E1 172.16.6.0 [110/11] via 10.1.12.2, 00:15:54, FastEthernet0/1
O E1 10.1.56.0 [110/11] via 10.1.12.2, 00:15:54, FastEthernet0/1
2#sh ip route rip
R 172.16.5.0 [120/2] via 10.1.26.2, 00:00:03, FastEthernet0/0
R 172.16.6.0 [120/1] via 10.1.26.2, 00:00:03, FastEthernet0/0
10.0.0.0/30 is subnetted, 7 subnets
R 10.1.56.0 [120/1] via 10.1.26.2, 00:00:03, FastEthernet0/0
2. Why the traceroute on R3 looks like this?
R3#traceroute 172.16.5.1
1 10.1.34.2 32 msec
10.1.13.1 12 msec
10.1.34.2 8 msec
2 10.1.12.2 8 msec
10.1.24.1 20 msec
10.1.12.2 16 msec
3 10.1.26.2 48 msec 40 msec 40 msec
4 10.1.56.1 40 msec 40 msec 40 msec
R3#traceroute 172.16.6.1
1 10.1.13.1 32 msec
10.1.34.2 12 msec
10.1.13.1 8 msec
2 10.1.24.1 8 msec
10.1.12.2 20 msec
10.1.24.1 16 msec
06-28-2015 06:03 AM
So, you have one of your routers learning the R5 and R6 routes through OSPF, and the other learning them through RIP. I think what you have is a race condition. It is the luck of the draw which one gets the OSPF routes and which on the RIP.
You see, as far as R1 and R2 are concerned, they will prefer an OSPF router over a RIP route because it has a lower administrative distance. The first of those routers, R1 or R2, to see the RIP advertisement from R5 and R6, will redistribute it into OSPF, where it will be seen by the other one. In your case, R2 saw the RIP first, and redistributed it to R1, which added it as an E1 to its routing table.
Try a debug ip routing. You might find your routes are flapping.
Does that make sense?
Kevin Dorrell
Luxembourg
06-29-2015 12:14 AM
Yes, that's correct. OSPF AS is 110 whereas RIP AD is 120. That is why R1 prefers OSPF information rather then RIP information. But why it is R2 which learns the R5 and R6 routes via RIP whereas R1 learns the R5 and R6 routes via OSPF and not vice versa. Does it mean that redistribution was configured first on R2 and then on R1?
BTW, Kevin Could you explain what does "routes are flapping" mean please.
06-29-2015 02:50 AM
Yes, it is just a question of whichever router gets to re-distribute the RIP route into OSPF first will keep the RIP route. The other one will learn the re-distibuted OSPF route from the first one.
Depending on how you have set up the ruting, you could get route flapping. By route flapping, I mean that the routing tables are unstable, flip-flopping between two different states. You would see this if you do a debug ip routing - you would see routes being continuously put into the routing table and taken out again. I don't think it will be the case here, but it would be as well to check. For example, it R1 re-distibutes the re-dirstributed route back into RIP with a low enough metwric, you could have a routing loop.
