routing and switching
aaa aaa
I wonder about configuring the console interface of the Cisco layer 2 switch for telnet or ssh purposes.
thanks in advance
Joseph W. Doherty
Yes, generally they can be so configured.  So you no longer need to wonder.  ;)
You mean that not through the vlan1 interface. Iam asking about how to configure the console to have an ip address ?
I'm unaware of a method to assign an IP to the console port.
For remote console access, what's commonly done, either a modem is connected to the console port, and you dial that modem, in answers, and you then telnet or SSH via the modem connection.
Or, you have a terminal server that responds on an IP.  You connect to the terminal server using its IP and a port number which in turn reverse telnets to the console port of the device.
Some newer Cisco devices do provide an IP enabled dedicated management port.
