routing b/w layer 2 and layer 3
susim
Level 3
Level 3
in vlan 3  i have some  pc's configured static ip s , i want to access from   vlan 3 to vlan 2 and vice versa
Please help
interface Vlan3
interface Vlan2
description Data-VLAN
ip address 192.168.0.1 255.255.255.0
Sorry  for being such  a great  dumb  newbie
devils_advocate
Level 7
Level 7
In order to get traffic from one vlan to another, your device needs to be capable of routing.
First enable routing:
#conf t
#ip routing
Then give Vlan 3 an IP address:
#conf t
#interface vlan 3
#ip address 192.168.1.1 255.255.255.0
Give your clients a default gateway of 192.168.1.1
Amit Singh
Which switch is this? You need to configure an IP on interface vlan which will be the gateway for Vlan 3 hosts and then enable IP routing for intervlan routing. Bydefault IP routing is enabled on most switches.
If its not a multi-layer 3 switch, you would need an external L3 capable device for this to work.
