Routing between Cisco 1720 and PIX 501
jay.johnson1
I'm currently attempting to run a 1720 as an edge router with a PIX 501 behind it. As of now, I can pull a public IP on the 1720's WAN interface (I'm using a WIC-1ENET card with broadand) but I can't get any activity from the fa0 port.
However, if I when I put a Linksys WRV200 in front of the pix, I can pass traffic to the computers sitting behind the pix and route without any issues.
My goal is to remove SOHO devices from gateway positions and use industry rated hardware instead. Provided I get some responses, I'll post configs if need be.
Jay
Certified: CCNA (R/S, Security, Voice), CCDA, CCNP (R/S)
15 Replies 15
Way ahead of you, Endwigast :)
I literally "played around" with some settings I got from a few other people and it just fired up a few minutes ago. I'm not routing with my 2610 :)
Here's the end result:
version 12.3
hostname London1
boot-start-marker
boot-end-marker
no logging console
enable secret xxx
enable password xxxxx
no aaa new-model
ip subnet-zero
ip cef
ip dhcp pool guardtower
network 172.16.31.0 255.255.255.0
dns-server 87.xxx.xxx.30
default-router 172.16.31.1
interface Ethernet0/0
description "The Great Outdoors (WAN)"
ip address dhcp
ip nat outside
full-duplex
no cdp enable
interface Ethernet1/0
description "Private LAN"
ip address 172.16.31.1 255.255.255.0
ip nat inside
half-duplex
no cdp enable
router rip
network 172.16.0.0
ip default-gateway 87.xxx.xxx.7
ip nat inside source list 1 interface Ethernet0/0 overload
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 Ethernet0/0
access-list 1 permit any
no cdp run
line con 0
line aux 0
line vty 0 4
password xxxxx
login
End
At last, I can go to sleep...
Jay
