Routing between Cisco 851 and 871 problem!
TiagoRebelo
Hi all,
I´m having a problem in configuring routing between 2 Cisco 800 series.
I am trying to connect this 2 routers with a cross cable in the FA4 (WAN interface) to test a VPN tunnel in a lab enviroment, but i am having some issues in reaching the remote LAN´s.
I have joined the 2 router´s FA4 interface in the same network, and they can reach each other. In the interface´s Vlan1 in each Router that agregate the switching module (Fa0-Fa3) i have created a network Lan.
The problem is when static routes or RIP are implemented, i can ping the remote router Vlan´s interface... but i can´t reach the host´s that are in that  network!
Router´s Wan interface (192.168.0.1; 192.168.0.2) /30
R1 Int VLAN 1 - 192.168.1.1 /24
R2 Int VLAN 2 - 192.168.2.1 /24
I´m sure that something is missing.
Hope anyone can advise.
Best Regards,
8 Replies 8
Reza Sharifi
Make sure you have the correct default gateway configured on the hosts.  For host in subnet VLAN 1 - 192.168.1.1 /24 the default gateway should be 192.168.1.1 and for the host in subnet VLAN 2 - 192.168.2.1 /24 the default gateway should be 192.168.2.1
Reza
Hi Reza Sharifi,
Thanks for participate in my topic.
The host´s default gateway are correct, because i can reach other networks.
An example, I can ping from a host in the Router 1 VLAN1 network, to the Router 2 VLAN1 (192.168.2.1)... but i can´t ping the test host with 192.168.2.2.
I have an host in each router´s Vlan, both hosts can ping all local and remote router interfaces, but the host can´t ping each other. :S
I think the missing problem is on the interface VLAN, that aggregates the switching module on the 800series.. but i can´t see what´s missing.
When i implement RIP.. the routes are advertised in both routers.
Best Regards,
hi tiago,
kindly post your show ip route and show run on both routers.
Hi John,
i´m not at office, i will post the outputs ASAP.
The outputs of the routers:
RUNNING CONFIG ROUTER
Current configuration : 2931 bytes
version 12.4
no service pad
hostname Router1
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp pool Lan1
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
no ip domain lookup
ip domain name yourdomain.com
username ******* privilege 15 secret 5 $1$N0H7$GzHWgHAjiIUQLddTemG2V1
archive
log config
  hidekeys
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address 192.168.0.1 255.255.255.0
duplex auto
speed auto
interface Vlan1
description Internal LAN R1
ip tcp adjust-mss 1452
ip forward-protocol nd
ip route 192.168.2.0 255.255.255.0 192.168.0.2
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
no cdp run
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
login local
transport input telnet ssh
scheduler max-task-time 5000
end
SHOW IP ROUTE ROUTER1
Gateway of last resort is not set
C    192.168.0.0/24 is directly connected, FastEthernet4
C    192.168.1.0/24 is directly connected, Vlan1
S    192.168.2.0/24 [1/0] via 192.168.0.2
SHOW RUN ROUTER 2
Current configuration : 3049 bytes
version 12.4
no service pad
hostname Router2
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
   import all
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
   lease 0 2
ip cef
no ip domain lookup
username ***** privilege 15 secret 5 $1$pzlG$M9vDRGcIFheRXm9RQ9Oad0
archive
log config
  hidekeys
ip address 192.168.0.2 255.255.255.0
ip virtual-reassembly
duplex auto
speed auto
interface Vlan1
description internal LAN R2
ip address 192.168.2.1 255.255.255.0
ip route 192.168.1.0 255.255.255.0 192.168.0.1
ip http server
no cdp run
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
end
SHOW IP ROUTE
S    192.168.1.0/24 [1/0] via 192.168.0.1
C    192.168.2.0/24 is directly connected, Vlan1
Best regards
your config looks good. could you post your PC's ipconfig and do ping/tracert end-to-end. kindly disable windows FW/AV while doing tests.
The routers seem to be configured correctly, so most likely an issue with the PCs.  Like somebody else mentioned, are you sure that Windows FW is turned off?
Hi Jonhlloyd and dbass,
The ipconfig´s are ok.
I´ve found the issue, the routers are ok! It was an ip conflit with the Checkpoint vpn client that i use to connect into a client network. I didn´t expect this application conflit because the host´s and the routers that ive used to test, weren´t connected to the internet and the checkpoint app wasn´t running..
Thanks for the help.
Best Regards,
