routing between Vlan switching
ankyrod2006
In a switch Catalyst 4500 Series, for rute between two VLAN, I only have to create VLAN with logical Layer 3 VLAN interfaces and to enable the ip routing.
I don't have to make another thing?
I Don't have to create new route?
This is I have to make ?
Switch(config) ip routing enabled
Switch(config)# vlan 2
Switch(config)# interface vlan 2
Switch(config-if)# ip address 192.168.249.10 255.255.255.0
Switch(config-if)# no shutdown
Switch(config-if)# end
Switch(config)# vlan 3
Switch(config)# interface vlan 3
Switch(config-if)# ip address 10.50.0.10 255.255.255.0
Thank you early
5 Replies 5
rbolenba
The routes for the L3 interfaces will show up as connected routes automatically.
Ryan
Then, with the configuration that I show previously it is enough ?
Yes. Verify with "sh ip route" once you configure.
Ryan
Hi Ank,
there is no need of enabling the routes in ur L3 card, as by default the routes will be enabled automatically(only on 3550/3750etc...) u need to enable the "ip routing") & ur configuration of VLAN will wrk 100% & there is no doubt on to it. all u need to do is when ever u connect a pc on some port in 4500 switch, u juz need to specify the switchport as eg."switchport access vlan 2" or "switchport access vlan 3".
hope this helps.
rate this post if cleared.
Thanks very much to every one
in my case I will implement it the ruteo with "logical Layer 3 VLAN interfaces"
I am not implementing with The physical Layer 3 interfaces "
But to the effects of the route I believe that it is the same thing
