Routing Cisco 2960-X
kwalsh109
I have a WAN connection and a point to point connection installed at my site.  Currently all traffic routes out the WAN connection.  I want to configure the interface (where my PTP is connected) to route specific traffic.  Can I accomplish this on this model switch. I see it has some routing capability. Thank you.
Julio E. Moisa
This model has routing limitation and works more over layer 2. But it has the capability to execute static routing only. My recommendation is a multilayer switch or router instead.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
You can have up to 16 statics on standard x, 2960-xr with ip lite might suit you better it can do basic IGP and l3
Table 2.       Comparison of Cisco Catalyst 2960 Switches
Feature
2960-XR
2960-X
2960-S
2960
CPU
Dual core at 600 MHz
Single core
Single core
Stacking
FlexStack-Plus
FlexStack-Plus
FlexStack
No
Stack bandwidth
80 Gbps
80 Gbps
40 Gbps
Stack members
8
8
Power supply
Dual FRU
Fixed
Fixed
Fixed
Redundant power supply (RPS)
Yes
No
No
No
PoE+ 30W/port
Yes
Yes
Yes
No
Max PoE budget
740W
740W
740W
External RPS
No***
Yes
Yes
No
SFP+ uplinks
Yes
Yes
Yes
No
Uplinks
2 SFP+/4 SFP
2 SFP+/4 SFP
2 SFP+/4 SFP
2 SFP
Management options
Console RJ45, USB console, and out of band Ethernet
Console RJ45
Flash
256 MB
128 MB
64 MB
32 MB
DRAM
512 MB
512 MB
256 MB
64 MB
Active VLANs
1K
1K
255
64
EtherChannel groups
48
24
6
6
Egress buffers
4 MB
4 MB
2 MB
2 MB
Switched Port Analyzer (SPAN) sessions
Max MAC addresses
32K*
16K
8K
8K
IPv4 unicast routes
24K**
16 static
16 static
16 static
NetFlow-Lite
Yes
Yes
No
No
Hibernation Mode
Yes
Yes
No
No
EEE
Yes
Yes
No
No
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/qa_c67-728348.html
Hi all,
Just revisiting this topic.
I have a similar scenario whereby my layer 3 device is an ASA.
I was thinking of moving the inter-vlan routing within my LAN to a stack of 2960x (running k9) image and let the ASA act only as a firewall.
It will not have more than 16 static routes I don't think.
However, one complication I foresee is that we currently have firewall rules applied for some of the VLANs accessing other VLANs. May be a nightmare trying to convert those rules into ACLs on the switch.
Also, the CPU on the current switch stack does run quite high certain times of the day.
Not sure if this should even be attempted.
Any feedback is much appreciated.
