routing descisions
carl_townshend
Hi all, can anyone tell me, If I have a router that has a static route pointing say the 10.0.0.0/8 network at another hop, I then redistribute this into my eigrp network, If then on another remote location I setup the 10.115.0.0/16 network and redistribute that into my eigrp network, will the router poiting the 10.0.0.0/8 network add the more specific route into its routing table and it should work ?
JamesLuther
Level 3
Level 3
Both routes will be populated into EIGRP and the more specific route will be used first.
So yes to your question.
