Routing different gateways.
lubosbella
Level 3
Level 3
Hello, want to ask for this:
I have cisco3560 switch with vlan configuration (ip address of vlan is gateway for hosts):
- vlan10 - 172.20.1.1/24
- vlan20 - 172.21.1.1/24
- vlan30 - ............
Default route is pointing to Linux router 10.0.0.1/24.
Now i want to route all traffic from vlan20 to ASA on ip 10.0.0.5/24 only.
Is there way how to do this? (probably policy based routing can do this but my cisco 3560 have no ip services image installed).
There is a picture in attachement for this scenario.
Thank you very much.
5 Replies 5
Reza Sharifi
Correct, in order to do PBR, you need IP Services license.
Thank,
and is any other possibility how to do it without PBR?
LB
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Might be doable using VRF(-lite), assuming it too doesn't need IPServices license.
Joe,
VRF-lite needs IP services license as well.
Reza
