Routing from L3 switch VLANs to router
bkyuksel
Hello Everyone,
I created VLAN SVIs on L3 switch and want to route them to another network through a router.
I wrote the command ip routing and done the ip route 0.0.0.0 0.0.0.0 (next hop as a gateway)
also tried ip default-gateway as routers interface as a next hope.
None of them helped. Could you please help me with this?
This is really weird, packet tracer is added as well.
M02@rt37
Hello @bkyuksel,
Add static default router on Router4:
Or add specific static routes like that:
After that you will be able to ping Server4 from Laptops...and vice versa.
Best regards
M02@rt37
Hello @bkyuksel,
Best regards
Thanks a lot, I was so blind. You made my day
