Routing issue eludes me
pi_networks
I have a test network setup that works 90% ... the last 10% is, I suspect, related to a single command that I just can't remember ..
Here's what works and what doesn't...
Any host in 10.1.15.0/24 (including the 3750 interface) can ping 192.168.59.221, 192.168.59.1, and any address on the internet. However, they CANNOT ping any other host on 192.168.59.0/24. (Firewalls have been rulled out)
Any host in 192.168.59.0/24 CAN ping any address on the internet AND any address 10.1.15.0/24. If I telnet from a host in 192.168.59.0/24 to the vlan 11 interface of the 3750 (10.1.15.1), the connection establishes, but beyond that there is no response from it. I even tried entering a static route on the host directing 10.1.15.0/24 to 192.168.59.221 to rule out the actiontec and had the exact same result.
Setup looks like this ...
internet gateway (fios - actiontec)
192.168.59.1/24 (inside interface)
|---192.168.59.0/24 hosts
192.168.59.221/24 (vlan 1)
cisco 3750
10.1.15.1/24 (vlan 11)
|---10.1.15.0/24 hosts
The actiontec has a route to 10.1.15.0/24 via 192.168.59.221 this all works.
The 3750 config is basically default with the vlans added and IP routing enabled.  It has a default route to 192.168.59.1 and there are no ACL's.
The worst part is that I'm sure I've run into this before and solved it with something simple .. but at this point I'm banging my head.
Any bright ideas would be appreaciated.
6 Replies 6
Martin Carr
Level 4
Level 4
Can you post the client network config?
Martin
All clients in 192.168.59.0/24 use 192.168.59.1 as their default gateway.
All clients in 10.1.15.0/24 use 10.1.15.1.
Is that what you are referring to?, or are you looking for configuration out of the 3750?  (I attached the 3750 Config)
The problem is you have set the incorrect gateway... it should be 192.168.59.221 for that network.
Martin
192.168.59.1 is an edge router with a defined route for 10.1.15.0/24 via 192.168.59.221.
As stated, any device on 192.168.59.0/24 can ping into 10.1.15.0/24 when initiated from the 192.168.59.X hosts ... I seem to be having a scenerio where one directly connected subnet can see into another, but not vice versa.
I know and what I have stated will work.
The problem is the class A network has no route back from the switch.
Martin
I found the issue, and it wasn't routing after all (I had only ruled out software firewalls on the clients).  The Actiontec, despite knowing the routes, properly handling NAT for both ranges, and that the relevant ranges were on the same interface; was applying firewall rules before routing it's own internal traffic.  Once the rules were added, everything worked like a charm.
Thanks for your input.
