Routing on a stick & ESXi
maguro403
I was wondering if I could get some advice regarding an issue I'm having. I'm sure it's something really trivial but it's been really bugging me to the point where I'm losing sleep. :)
I'm just playing around with ESXi 5.5 and I'm trying to route traffic between two VM's which are on different Vlans. (I attached a network diagram from vSphere.)
I have the cable plugged into the FE8 port on a Cisco 892 which is configured as below.
I'm testing connectivity using the ping command, which fails when I try to ping each other. (I've altered the appropriate settings to Win7 and ESXi to allow for pinging and I've cleared the arpcache.)
I've configured both VMs to use the subinterfaces as their gateways and I can ping those from the VMs. I can even ping the other gateway but nothing further.
"show ip route" on the 892 shows that it can see the 10.0.10.0/25 on interface FE8.10 and 10.0.20.0 on interface FE8.20.
I'm thinking it must be an ESXi thing or just plain stupidity on my part. Most likely the latter...
version 15.0
hostname Cisco892
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
 --More--         !
ip cef
no ipv6 cef
license udi pid CISCO892-K9 sn FGL154123NY
interface BRI0
 no ip address
 --More--          encapsulation hdlc
 shutdown
 isdn termination multidrop
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
 --More--         interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
 no ip address
 duplex auto
 speed auto
interface FastEthernet8.10
 description Vlan 10 from ESXi
 encapsulation dot1Q 10
 ip address 10.0.10.1 255.255.255.0
interface FastEthernet8.20
 description Vlan 20 from ESXi
 encapsulation dot1Q 20
 ip address 10.0.20.1 255.255.255.0
interface GigabitEthernet0
 --More--          no ip address
 shutdown
 duplex auto
 speed auto
interface Vlan1
 no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
 --More--          !
line con 0
 exec-timeout 0 0
 logging synchronous
line aux 0
line vty 0 4
 login
scheduler max-task-time 5000
end
Jon Marshall
If you can ping the other gateway as you say then virtually every time this is a firewall issue on the end device itself because by pinging the other gateway that proves it is routing between vlans.
What happens when you try to ping either server from the router ?
Jon
8 Replies 8
Jon Marshall
Jon
Jon,
Thanks for the prompt reply.
I can ping both servers from the router.
However, if I use (for example) : ping ip 10.0.10.101 source 10.0.20.1, it fails. (10.0.10.101 being my VM on vlan 10 and 10.0.20.1 being the subinterface for vlan 20 on my router)
You may find that you cannot remove the subinterfaces with "no int fa8.x".
If so just remove the IP address and the encapsulation command and shut the subinterface down.
Jon
I've not used this router but I don't think this is how you set it up because the port you are using is L2 only as far as I know and not L3.
So can you modify your configuration and try this -
no int fa8.10
no int fa8.20
int fa8
switchport
switchport trunk encapsulation dot1q  <--- if this isn't available don't worry, just ignore
switchport mode trunk
int vlan 10
ip address 10.10.10.1 255.255.255.0
no shut
int vlan 20
ip address 10.10.20.1 255.255.255.0
no shut
Jon
Jon,
This switch actually uses fa8 as a routable interface. Therefore, the switchport command is unavailable for this interface.
After posting my message last night, I actually pulled out a Cisco 3560G and configured two vlans (without configuring svi's and routing so it was just a layer 2 switch). I then plugged in 2 physical computers on different subnets into each vlan and used one port as a trunk to my Cisco 892 as a ROAS.
The router worked fine but when I swapped cables and plugged in the cable from my ESXi host, it wasn't able to route.
I guess it must be an ESXi thing. I'll try posting on the Vmware forum. :(
Ken.
Ken
My apologies, I didn't realise that.
Thanks for letting me know.
Jon
maguro403
Jon,
I turned off Windows firewall altogether on both VMs and it's working.
I thought allowing ICMP was enough but I guess it wasn't. I'll work on isolating the exact settings but in the meantime, I'd like to thank you for restoring my sanity. :)
Ken
No problem, at least now you can sleep easy :-)
Jon
