Routing problem due to OSPF issue with "O" versus "IA O"
aimarchitect
I would like to dscuss how an OSPF router might insert an intra area "O" OSPF route into the routing table when it seems that the route should have been an inter-area "IA O" route and therfore [due to precedence of O before IA O, regardless of cost] lost to a higher cost intra area "O" route.
The attached diagram helps illustrate the question.  Take note of the two ABR routers, C2 and S2.
C2 and S2 each have an interface in Area 14.  10.180.21.0/24 is configured in Area 14.  The router interface addresses in this network/Area are .17 and .22 respectively.  The OSPF cost on these interfaces is 1.
C2 and S2 also each have an interface in Area 0.  10.180.16.0/24 is configured in Area 0.  The router interface addresses in this network/Area are .4 and .6 respectively.  The OSPF cost on these interfaces is 5.
C2 and S2 are also configured with router-ids 10.180.20.4 and 10.180.20.6 respectively.  These host addresses are configured in Area 0 on each router.
Which interface should C2 use reach 10.180.20.6 (S2 router-id) and why?
Running a "show ip route | i 10.180.20.6" command on C2 does (but should not?) show this:
C2#sh ip route | i 10.180.20.6
O       10.180.20.6/32 [110/2] via 10.180.21.22, 1d08h, Vlan14
How can a route from C2 to 10.180.20.6 (S2) with the next hop 10.180.21.22 be considered an "O" if it is not going through Area 0?
How exactly can C2 know/classify the route to 10.180.20.6 (S2) via 10.180.21.22 as an "O" instead of an "IA O"?
Thanks for any responses...
Hello Greg,
thanks for your kind update to this thread.
It has been wise to open a TAC service request.
The virtual link was not mentioned in previous posts, however it was not immediate to think of this kind of consequences of its presence.
Best Regards
Giuseppe
10 Replies 10
Edwin Summers
Level 3
Level 3
I may not fully understand your question, but the route learned by C2 to 10.180.20.6 *would* be an intra-area route.  Intra-area routes originate and are learned in the same area (it doesn't have to traverse Area 0).  Intra-area routes are indicated by the "O".  As the route was originated in Area 1, and learned on C2's Area 1 interface (next hop is 10.180.21.22, it is an intra-area ("O") route.
Inter-area routes are routes that originate in one area and learned in another.  Those are the "IA O" routes.
Hopefully I've helped some?  Best, -Ed
Oops! Just read Giuseppe's comment and realized I missed your note that the loopbacks were configured to Area 0.  Sorry for the confusion! -Ed
Giuseppe Larosa
Hello Greg,
if I understand correctly Vlan14 is part of area 14 and from the network diagram we see that both C2 and S2 nodes are ABR  between area 0 and area 14 ABR(0,14).
You say that loopback addresses have been advertised with network .... area 0 command.
I agree the expected output should be an O route in area 0 with IP next-hop 10.180.16.6.
Here we an O route in area 14.
So first I would check if IP connectivity and  OSPF relationships are correctly setup in area 0 for the lan segment associated to the IP subnet 10.180.16.0/24.
You can use
show ip ospf neighbors
on C2 to see if all the expected neighbors are seen or not.
The second aspect  that can be examined is the OSPF database
you can use on C2 node:
show ip ospf database advertising-router 10.180.20.6
to see all LSA generated by S2.
show ip ospf database router 10.180.20.6
You should see two Router LSA one built for area 0 and one for area 14 if IP connectivity and OSPF are fine in subnet 10.180.16.0/24.
the show ip route that you have provided looks like compatible with a scenario where C2 receives only the router LSA in area 14 from S2 and no router LSA for S2 in area 0 with loopback interface IP address matching a network ... area 14 command on S2. This may be caused by some possible cases: S2 actually configured as an internal router in area 14, S2 or C2 without any active link to area 0.
You can use
show ip ospf
to have information about OSPF on S2 and you should verify it is running for area 0 and area 14.
Hope to help
Giuseppe
Giuseppe,
Thank you for taking the time to read my post.
I'm glad you understand the problem...the route from C2 to the loopback router-id address 10.180.20.6 on S2 should not be intra-area via 10.180.21.22 in Area 14 (VLAN 14).  Instead it should be intra-area via 10.180.16.6 in Area 0 (VLAN 10).
Exactly what process and data does C2 use to make its deciscions about classifying routes as intra-area or inter-area?
Here is the output of some show commands run on routers C2 and S2:
C2#sh ip ospf nei
Neighbor ID     Pri   State           Dead Time   Address         Interface
10.180.20.6       1   2WAY/DROTHER    964 msec    10.180.16.6     Vlan10
10.180.20.6     254   FULL/BDR        00:00:30    10.180.21.22    Vlan14
[output omitted]
C2#sh ip ospf database adv-router 10.180.20.6
            OSPF Router with ID (10.180.20.4) (Process ID 65525)
                Router Link States (Area 0)
Link ID         ADV Router      Age         Seq#       Checksum Link count
10.180.20.6     10.180.20.6     1392        0x80008555 0x001215 7
                Net Link States (Area 0)
[output omitted]
                Summary Net Link States (Area 0)
[output omitted]
                Summary ASB Link States (Area 0)
[output omitted]
                Router Link States (Area 14)
10.180.20.6     10.180.20.6     1514        0x800084FB 0x005192 4
                Summary Net Link States (Area 14)
10.180.20.6     10.180.20.6     1758        0x800084C8 0x00B18C
[output omitted]
                Summary ASB Link States (Area 14)
[output omitted]
                Type-5 AS External Link States
Link ID         ADV Router      Age         Seq#       Checksum Tag
[output omitted]
C2#
C2#sh ip ospf int brie
Interface    PID   Area            IP Address/Mask    Cost  State Nbrs F/C
Vl10         65525 0               10.180.16.4/23     5     DROTH 2/9
Vl14         65525 14              10.180.21.17/28    1     DR    6/6
[output omitted]
C2#sh run | s ospf
router ospf 65525
router-id 10.180.20.4
log-adjacency-changes
area 0 authentication message-digest
area 14 authentication message-digest
redistribute static subnets
network 10.180.20.4 0.0.0.0 area 0
network 10.180.16.0 0.0.1.255 area 0
network 10.180.21.16 0.0.0.15 area 14
[output omitted]
C2#sh ip proto
*** IP Routing is NSF aware ***
Routing Protocol is "ospf 65525"
  Outgoing update filter list for all interfaces is not set
  Incoming update filter list for all interfaces is not set
  Router ID 10.180.20.4
  It is an area border and autonomous system boundary router
  Redistributing External Routes from,
    static, includes subnets in redistribution
  Number of areas in this router is 2. 2 normal 0 stub 0 nssa
  Maximum path: 4
  Routing for Networks:
[output omitted]
  Passive Interface(s):
[output omitted]
  Routing Information Sources:
    Gateway         Distance      Last Update
    10.180.20.6          110      02:01:25
[output omitted]
S2#sh ip ospf nei
10.180.20.4       1   2WAY/DROTHER    872 msec    10.180.16.4     Vlan10
10.180.20.4     255   FULL/DR         00:00:38    10.180.21.17    Vlan14
[output omitted]
S2#sh ip ospf database adv-router 10.180.20.4
            OSPF Router with ID (10.180.20.6) (Process ID 65525)
10.180.20.4     10.180.20.4     19          0x8000DE41 0x007EFA 13
[output omitted]
[output omitted]
[output omitted]
10.180.20.4     10.180.20.4     60          0x8000B133 0x00C010 2
[output omitted]
10.180.20.4     10.180.20.4     60          0x8000B121 0x009923
[output omitted]
[output omitted]
S2#
S2#sh ip ospf int brie
Vl10         65525 0               10.180.16.6/23     5     DROTH 2/9
Vl14         65525 14              10.180.21.22/28    1     BDR   6/6
[output omitted]
S2#sh run | s ospf
router ospf 65525
router-id 10.180.20.6
network 10.180.20.6 0.0.0.0 area 0
[output omitted]
S2#sh ip proto
  Router ID 10.180.20.6
  Maximum path: 4
[output omitted]
[output omitted]
[output omitted]
    10.180.20.4          110      01:59:35
Hello Greg,
both routers C2 and S2 are ABR between area 0 and area 14.
However, at the same time both routers are ASBR because they inject routes into the OSPF domain
Both area 0 and area 14 are standard areas:
It is the fact that S2 is an ASBR that changes the game rules: routing to S2 Router-id can be performed by using LSA type 4 information.
LSA type 4 information is present in area 0 and in area 14 for 10180.20.6/32.
At this point the route in area 14 is preferred for the lowest cost over the path in area 0.
With this lab setup we see the effective use of LSA type 4.
You have omitted the output but the section relevant ot LSA type 4 is
[output omitted]
and there is an LSA Type4 in area 14 generated by S2 that describes how to reach S2 router-id
This makes the route via Vlan14 comparable ( of the same type O instead of O IA) to that via vlan10.
the
show ip ospf database router 10.180.20.6 detail
on C2 should show that the router LSA in area 14 does not include the loopback address 10.180.20.6
If S2 wouldn't be an ASBR the only route would have been via vlan10 in area 0 learned by Router LSA in area 0.
Being S2 an ASBR the comparison is performed on LSA type4 information,
Hope to help
Giuseppe
Hi Giuseppe,
You are right, I see that a Type 1 LSA for S2 router-id 10.180.20.6 is not present in the Area 14 database on C2.  And yes, a Type 4 LSA for S2 router-id 10.180.20.6 is presnt in the Area 0 and Area 14 databases on C2 (see show ip ospf datbase command output below).
Do I understand correctly that C2 takes the Type 4 LSA from the Area 14 database for 10.180.20.6 to make this routing table entry?
C2#sh ip route 10.180.20.6
Routing entry for 10.180.20.6/32
  Known via "ospf 65525", distance 110, metric 2, type intra area
  Last update from 10.180.21.22 on Vlan14, 02:09:58 ago
  Routing Descriptor Blocks:
  * 10.180.21.22, from 10.180.20.6, 02:09:58 ago, via Vlan14
      Route metric is 2, traffic share count is 1
C2#sh ip ospf dat router 10.180.20.6
  Routing Bit Set on this LSA
  LS age: 318
  Options: (No TOS-capability, DC)
  LS Type: Router Links
  Link State ID: 10.180.20.6
  Advertising Router: 10.180.20.6
  LS Seq Number: 800085FA
  Checksum: 0xC6BA
  Length: 108
  Area Border Router
  AS Boundary Router
  Number of Links: 7
    Link connected to: a Virtual Link
     (Link ID) Neighboring Router ID: [output omitted]
     (Link Data) Router Interface address: [output omitted]
      Number of TOS metrics: 0
       TOS 0 Metrics: 1
    Link connected to: a Stub Network
     (Link ID) Network/subnet number: [output omitted]
     (Link Data) Network Mask: [output omitted]
       TOS 0 Metrics: 1
       TOS 0 Metrics: 1
    Link connected to: a Transit Network
     (Link ID) Designated Router address: [output omitted]
       TOS 0 Metrics: 1
     (Link ID) Network/subnet number: 10.180.20.6
     (Link Data) Network Mask: 255.255.255.255
       TOS 0 Metrics: 1
       TOS 0 Metrics: 5
       TOS 0 Metrics: 5
  LS age: 317
  LS Seq Number: 800085A0
  Checksum: 0x539
  Length: 72
  Area Border Router
  AS Boundary Router
  Virtual Link Endpoint
  Number of Links: 4
    Link connected to: another Router (point-to-point)
       TOS 0 Metrics: 250
       TOS 0 Metrics: 250
       TOS 0 Metrics: 1
       TOS 0 Metrics: 1
C2#sh ip ospf dat asbr-summary 10.180.20.6
  LS age: 909
  Options: (No TOS-capability, DC, Upward)
  LS Type: Summary Links(AS Boundary Router)
  Link State ID: 10.180.20.6 (AS Boundary Router address)
  Advertising Router: 10.180.20.4
  LS Seq Number: 8000107D
  Checksum: 0xA35B
  Length: 28
  Network Mask: /0
        TOS: 0  Metric: 1
  LS age: 3 (DoNotAge)
  Advertising Router: [output omitted]
  LS Seq Number: 800007B7
  Checksum: 0x5661
  Length: 28
  Network Mask: /0
        TOS: 0  Metric: 10
  LS age: 382
  LS Seq Number: 80000063
  Checksum: 0x2CDA
  Length: 28
  Network Mask: /0
        TOS: 0  Metric: 16
  LS age: 156
  LS Seq Number: 80003055
  Checksum: 0xBB47
  Length: 28
  Network Mask: /0
        TOS: 0  Metric: 5
  Adv Router is not-reachable
  LS age: 572
  LS Seq Number: 8000107B
  Checksum: 0xB337
  Length: 28
  Network Mask: /0
        TOS: 0  Metric: 10
  LS age: 883
  LS Seq Number: 8000304E
  Checksum: 0x6194
  Length: 28
  Network Mask: /0
        TOS: 0  Metric: 6
C2#
Hello Greg,
S2 Router LSA in area 14 hasn't an entry for S2 10.180.20.6 and this is like expected.
Yes the route on C2 is derived from LSA type 4 in area 14 originated by S2 and referring to S2 router-id 10.180.20.6.
However, I don't see that specific LSA in the show command that you have reported.
Notice that the last LSA in area 14 that you have noticed (using bold) is originated by C2 itself ( advertising router 10.180.20.4).
Hope to help
Giuseppe
Hi Giusepe,
This is tough issue and we are about to open a TAC case with the intention of getting an OSPF developer.
You are saying:
...the route on C2 is derived from LSA type 4 in area 14 originated by S2 and referring to S2 router-id 10.180.20.6.
The route destination (S2 router-id 10.180.20.6) is in Area 0, so how can an Area 14 link (VLAN 14) ever be considered Intra Area for Area 0?  An Intra Area, Area 0 path should never leave Area 0, right?
I don't see a Type 4 LSA in Area 14 originated by S2 and referring to S2 router-id 10.180.20.6  Are these the right commands to run on S2 to look for it?
S2#sh ip ospf dat asbr-summary 10.180.20.6
  LS age: 1989
  LS Seq Number: 8000117A
  Checksum: 0xA65A
  Length: 28
  Network Mask: /0
        TOS: 0  Metric: 1
  LS age: 1 (DoNotAge)
  Advertising Router: [output omitted, not 10.180.20.6]
  Checksum: 0x5661
  Length: 28
  Network Mask: /0
        TOS: 0  Metric: 10
  LS age: 186
  LS Seq Number: 8000002E
  Checksum: 0x96A5
  Length: 28
  Network Mask: /0
        TOS: 0  Metric: 16
  LS age: 475
  LS Seq Number: 80003152
  Checksum: 0xBE46
  Length: 28
  Network Mask: /0
        TOS: 0  Metric: 5
  LS age: 583
  LS Seq Number: 80001178
  Checksum: 0xB636
  Length: 28
  Network Mask: /0
        TOS: 0  Metric: 10
  LS age: 963
  LS Seq Number: 8000314B
  Checksum: 0x6493
  Length: 28
  Network Mask: /0
        TOS: 0  Metric: 6
S2#sh ip ospf dat asbr-summary self-originate
  LS age: 1469
  Link State ID: 10.180.20.4 (AS Boundary Router address)
  LS Seq Number: 80001177
  Checksum: 0xB44F
  Length: 28
  Network Mask: /0
        TOS: 0  Metric: 1
  LS age: 1469
  Link State ID: [output omitted, not 10.180.20.6] (AS Boundary Router address)
  Checksum: 0x50A9
  Length: 28
  Network Mask: /0
        TOS: 0  Metric: 1
  LS age: 1998
  LS Seq Number: 80003150
  Checksum: 0xE821
  Length: 28
  Network Mask: /0
        TOS: 0  Metric: 5
  LS age: 1998
  Checksum: 0xDE2A
  Length: 28
  Network Mask: /0
        TOS: 0  Metric: 5
  LS age: 476
  LS Seq Number: 8000319A
  Checksum: 0x229E
  Length: 28
  Network Mask: /0
        TOS: 0  Metric: 2
  LS age: 1
  LS Seq Number: 80003151
  Checksum: 0xC83D
  Length: 28
  Network Mask: /0
        TOS: 0  Metric: 5
  LS age: 3
  LS Seq Number: 8000866B
  Checksum: 0x6237
  Length: 28
  Network Mask: /0
        TOS: 0  Metric: 1
  LS age: 4
  Checksum: 0x8C73
  Length: 28
  Network Mask: /0
        TOS: 0  Metric: 5
Here is an update.  With the help of Cisco TAC we are on the road to understanding how the Area 0 loopback of C2 routes to the Area 0 loopback of S2 across Area 14 and calls it "intra area".
Something not pictured in the original diagram is that S2 has a Virtual Link to a router in Area 14.  Still need verification, but it seems that the existence of this Virtual Link, coupled with the default "on" state for "capability transit" allows the above noted condition to occur.
Here are a couple of links (one provided by Cisco TAC) that I am looking at now with relation to this:
http://blog.ine.com/2009/09/14/understanding-ospf-transit-capability/
http://ieoc.com/forums/t/4807.aspx
Hello Greg,
Best Regards
Giuseppe
Hi Giuseppe,
Sorry about not including the point of the Virtual Link in the original post.  I was trying to simplify to the example.  I was wrong to think it was not relevant.
I have now read the "Understanding OSPF Transit Capability" link above and found that it does indeed describe the behaviour we see in the network.
Especially, this part of the article describes it perfectly:
"What’s really interesting, is that an intra-area route actually takes the INTER-area path! The transit capability essentially allows the use of non-backbone inter-area routes to optimize inter-area paths and area 0 intra-area paths IF the area in question is transit!"
So this question is answered.  If you see routing between Area 0 prefixes going through Non-0 Areas, and being listed in the routing table as "O" and "intra area" it may be confusing, but it is not wrong.  This is the work of OSPF Transit Capability.
