Configuring a Vlan
valcon5455
Community Member
I have a network with IP phones. The phones are connected to the switch and the computers are connected to the phones. How can I setup a vlan on the switch.to.route traffic comming from the phone to 1 router and the computer data through another router.
tipically configuration is:
for the phone:
interface FastEthernetXX
switchport trunk native vlan
switchport trunk allowed vlan ,
switchport mode trunk
switchport voice vlan
switchport trunk native vlan is if you want to get access whitout ip phone
and you can configure an access port with different vlan, one for the voice router and one for the data router.
example:
vlan 10
name voice
vlan 20
name data
int f0/1
desc to router voice
switchport mode access
switchport access vlan 10
int f0/2
desc to router data
switchport access vlan 20
Vincent
8 Replies 8
ameya_oke
Level 6
Level 6
You just need to configure the gateway for phone on one router and gateway for PC on another.
I would suggest you go for HSRP for making your LAN redundant.
Please rate the helpful posts.
Warm Regards,
Ameya Oke
thanks for the reply but i want the voice router to assign dhcp to the phones and i want the workstations to grab ips from the server behind the data router. I plan on replacing the current switch (unmanaged) with this
WS-C3560-48TS-E . If i setup the VLans how do i prevent the phones from grabbing an ip from the server on the data network or will this be done automatically because the switch will know the difference between a phone and computer.
This should be taken care of by the VLAN. You are segmenting the traffic to two "logical" networks.
fredareid
Level 2
Level 2
Depending on how it is set up but you could use the Voice vlan command on the ports.
Set the access VLan (switchport access Vlan) on the interface then add "switchport voice vlan #" to the interface.
Som reference material:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.1_19_ea1/configuration/guide/swvoip.html
for the phone:
example:
vlan 10
name voice
vlan 20
name data
int f0/1
int f0/2
desc to router data
Vincent
Yup... I got your point.... If you are going to make that switch as to support ip phone and
vlan 10
vlan 20
interface FastEthernet0/2
description **User port**
switchport access vlan 20 === Data VLAN
switchport voice vlan 10 == Voice VLAN
load-interval 60
ip dhcp snooping limit rate 10
int vlan 10
desc voice vlan
ip add 10.0.0.254 255.255.255.0
int vlan 20
desc data vlan
ip add 20.0.0.254 255.255.255.0
Just define your gateway as the router ip's in your phone or pc.....
10.0.0.1 for phone... 20.0.0.1 for pc.......
the traffic will go as per the dgw defined in your phone or pc.....
if you have many layers in your network befor tht router...... then it needs to be taken accordingly.....
is not necessary
int vlan 10
desc voice vlan
int vlan 20
desc data vlan
only if you want comunication between vlan data and voice or if you want ip management of the switch from vlan data and voice
Hi Vincent,
But switch mode trunk is not neccessary here in this scenario.... but you are right...so i updated in my earlier post considering the management IP for the Switch from both the vlans.... i suppose my scenario will definitely work for the raised query... Thanks.
Please do rate for the helpful posts!
