Routing problems on cisco 2811(works as NAT server)
triviacisco
Good day, Cisco experts.
I've got some problems in routing packets between two local networks(10.0.1.* and 10.0.2.*), i think that problem is related to NAT.
So could you, experts, give me advice in solving this problem.(tell me what should i read, or study, or what should i change in cisco 2811 configuration file and why for example)
Problem description:
Required to make following:
each network should see each other(10.0.1.* see 10.0.2.*, and 10.0.2.* see 10.0.1.*)
Now network 10.0.2.* sees 10.0.1.*, but network 10.0.1.* doesn't see 10.0.2.* network.
cisco 2811 configuration file:
interface FastEthernet0/0
description Internet
ip address IP_ADDRESS_AND_SUBNET_MASK _OUTSIDE
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
description $ES_LAN$
ip address 10.0.1.254 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/0/3
switchport access vlan 10
interface Vlan 10
ip address 10.0.2.254 255.255.255.0
ip nat inside source list NAT interface FastEthernet0/0 overload
ip nat inside source static tcp 10.0.1.100 80 IP_ADDRESS_OUTSIDE 80 route-map nonat extendable
ip nat inside source static tcp 10.0.1.100 443 IP_ADDRESS_OUTSIDE 443 route-map nonat extendable
ip nat inside source static tcp 10.0.1.100 3389 IP_ADDRESS_OUTSIDE 5101 route-map nonat extendable
ip nat inside source static tcp 10.0.1.100 3389 IP_ADDRESS_OUTSIDE 5102 route-map nonat extendable
ip access-list extended NAT
deny   ip 10.0.2.0 0.0.0.255 10.0.1.0 0.0.0.255
deny   ip 10.0.1.0 0.0.0.255 10.0.2.0 0.0.0.255
permit ip 10.0.1.0 0.0.0.255 any
route-map nonat permit 777
match ip address NAT
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
On work stations and servers in networks 10.0.1.* and 10.0.2.* default gateway configuration are 10.0.1.254 10.0.2.254, respectively.
Jon Marshall
What vlan is 10.0.1.x allocated to. What device have you got connected to fa0/1and what device have you got connected to fa0/0/3 and what are their configurations ?
Jon
Timothy Stewart
The configuration doesn't look like it should stop any communications between 10.0.2.0 and 10.0.1.0.  NAT should not take part in packets being routed between those two networks.  It should only be involved in packets between F0/1 and F0/0.    Just to be sure, I setup your configuration in the lab and had no problems with pinging between 10.0.1.0 and 10.0.2.0.  Pinging between 10.0.2.0 and the "Internet" resulted in NAT not being used (since nat inside is not configured on 10.0.2.0), whereas pinging between 10.0.1.0 and the "Internet" resulted in a dynamic translation.
Since you said traffic in one direction works (10.0.2.0 -> 10.0.1.0) but not in the other direction check the arp cache and routing (default route, etc) on the 10.0.1.0 devices.  If you disable ip nat inside on F0/1 does it resolve your problem (I wouldn't expect it to).
