01-23-2007 07:32 PM - edited 03-05-2019 01:56 PM
I am trying to configure a 7200VXR with a PA-2FE-TX I just installed. I want to set the 0-port of this adapter to the internal network (192.168.1.0/24) and the 1-port to the external/ISP network (63.0.0.0/8). The router's internal address is 192.168.1.1 and external address is 63.106.39.108. The default gateway on the external/ISP network is 63.106.39.1. I can ping 63.106.39.1 (as well as hosts on the Internet) from the router but not from a host (client PC) on the internal network, though the internal host can ping 192.168.1.1. I've set a static route of 0.0.0.0 0.0.0.0 63.106.39.1. Is there something else I need to set/apply to make this work? Thanks in advance for your time...
Solved! Go to Solution.
01-24-2007 08:59 AM
Troy,
Glad that it resolved your issue. Thanks for the update.
Rate the post if it was useful.
-Sundar
01-23-2007 07:57 PM
Troy,
The one thing you are missing is NAT. You need to use a globally routable address to access to the Internet. Configure NAT (PAT) to use the outside interface IP as the source of all traffic from your LAN.
You need a config similar to this one;
int f0/0
ip nat inside
int f0/1
ip nat outside
ip nat inside source list 150 interface f0/1 overload
access-list 150 permit ip 192.168.1.0 0.0.0.255 any
Sundar
01-24-2007 07:22 AM
Sundar,
Yes, that did the trick. It works like a champ now. I should have known to do this. Thanks for knocking the cobwebs loose!
Thanks!
Troy
01-24-2007 08:59 AM
Troy,
-Sundar
