Routing via a Layer 3 Switch
Dwayne Phills
I have a question about traffic traversing a layer 3 switch (6509).  Currently, we have a 6509 acting as the gateway for all nodes.  There is consideration of moving the gateway to the internal routers.  If the gateway routers would have router-on-a-stick, and an end-node try to communicate to another node on a seperate vlan (but on the same switch); would the traffic ever leave the backplane of the switch?  Baring the nodes default gateway are now changed to the gateway routers.
*** If anyone could add the pros and cons of switching the gateways, that would be excellent. ***
Thank you.
Elton Babcock
I would surely stay with the 6509 doing the routing for you. If you moved your routing closer to the clients, maybe 3570 switches would be the answer.
5 Replies 5
Jeff Van Houten
Level 5
Level 5
I'm curious as to what the benefit of this proposal is. Router on a stick over svi on an l3 routing switch? Must be one hell of a router.
is that your constructive answer?
It's not an answer at all. It's a question.
Elton Babcock
Thanks Elton.  I'm sure we will stay with the 6509s.
