routing with source issue
Sharin Taib
Hi wise ones.
I have a routing issue. I am attempting to setup a monitoring tool on the monitoring PC(192.80.175.139)
but the PC is unable to see the interface(72.19.255.41)
When i attempted a trace route, it stops at this router(192.80.175.136)
And here's the funny part
gateway#trace 72.19.255.41
Tracing the route to 72.19.255.41
  1 192.80.162.6 0 msec 0 msec 0 msec
  2 10.10.20.10 [MPLS: Label 45 Exp 0] 4 msec 0 msec 4 msec
  3 10.10.20.130 0 msec *  0 msec
sttpgw4#trace 72.19.255.41 so 192.80.175.136
  1  *  *  *
  2  *  *  *
And the monitoring PC is as such
NMS-R#trace 172.19.255.241
Tracing the route to 172.19.255.241
  1 202.80.175.136 0 msec 0 msec 0 msec
  2  *  *  *
What is the issue here? The interface, 72.19.255.41 is able to trace all the way to the monitoring PC
router2#trace 202.80.175.4
Tracing the route to 202.80.175.4
  1 10.10.20.129 180 msec 200 msec 0 msec
  2 10.10.30.1 0 msec 4 msec 4 msec
  3 10.10.10.9 0 msec 0 msec 4 msec
  4 192.80.162.5 0 msec 0 msec 4 msec
  5 192.80.175.139 4 msec 4 msec 0 msec
cadet alain
can you post your topology diagram please.
Regards.
Alain
192.80.175.139 -> 192.80.162.5 -> 192.80.162.6 -> 10.10.20.10 -> 10.10.20.130 / 72.19.255.41 -> 72.19.255.42
Sharin,
When you traced back to the monitoring PC, you used ip: 202.80.175.4. Is this the NATed ip for
192.80.175.139 or its another interface of the same PC?
Another point I would like to make is: you need to trace Monitoring PC using the source as 72.19.255.41, because by default it will use WAN interface as the source ip.
And based on the Trace outputs towards 72.19.255.41, it seems that the MPLS cloud is not aware of this 192.80.175.139 subnet/ip. Are you running BGP or any other routing protocol with the MPLS provider? And have you advertised your LAN in the cloud?
Hope it helps.
Neeraj
202.80.175.4 is the public IP, which is directly connected to 192.80.175.139. ergo, you need to pass through 192.80.175.139 before hitting 202.80.175.4
yes, tried tracing from 72.19.255.241 all the way to 202.80.175.4. it works. only it doesn't work as mentioned above.
yes, the 192.80.175.139 is on a different network, connected between 192.80.162.5 -> 192.80.162.6
