Routing
Please check the attachment!
I have a central central with connectivity over IPLC circuits to two other office locatoins.
Location Y : Has a 5 E1 links to CO & is connected to Location X over 2 6Mbps MAN link. EIGRP is the routing protocol in use.
Location X : It has two routers, 4 E1 links on each router connecting to CO. EIGRP in use.
CO : Has connectivity to other location on MPLS - EIGRP & BGP are in use on this router at CO
Now, we have acquired a new link - POint to point -1DS3 on Router1 in Location X connected to CO. What should be the routing protocol that can be used? I need to have the DS3 link as the primary link & the 8 E1 links to be as backup.
If I configure EIGRP on the link, All the traffic via location Y to CO will traverse like : Location Y -- via MAN links --> Loaction X -- via DS3 --> CO.
I do not want this to happen.
How do I acheive this ?
What would happen if I configure BGP on the DS3 link ? This way, it'll take care of my 1st requirement, i.e, All the traffic would get routed via DS3 & the 8 E1 links will be in use only when the DS3 goes down. Is that right?
Please help!
24 Replies 24
Location z : One switch & two routers.
Switch providing LAN connectivity & router-1 to Location x core switch & router-2 to location y core switch. EIGRP is the routing protocol.
Location x : one core switch & two routers. Router 1 & 2 have connectivity to CO via 8 E1 links & router 1 has a ds3 connection to CO. Core switch connected to Location Y switch over 6 Mb X 2 links & connected to location z via a 4Mb link.EIGRP in use.
Location Y : One core switch & two routers. core switch connected to location z [4Mb link] & connected to location Y [6Mb X 2].
CO connected as said.
CO is also connected to other locations via MPLS - BGP.
Subnet details across locations!
Ex : 10.136.x.x --> Location X
10.128.x.x --> Location Y
10.138.x.x --> Location Z
10.5.x.x --> CO
Also, at each location we have separate subnets for data, voice, printer VLANs
EX:For Location X
10.136.1.x-10.136.5.x(255.255.255.0)--> Data
10.136.20.x-10.136.25.x(255.255.255.0) --> voice
& so on...
read it carefully and apply, test it and tell
Thank you!
I'll get back to you with the results tomorrow.
is it working or not ?
I've tried this & looks like it works.
Thank you!
if its worked
please, rate the helpful post
and good luck
Giuseppe Larosa
Hello Deepa,
you can achieve what you want with EIGRP by manipulating EIGRP metrics on the MAN links between location Y and location Z
take a sh int of interface connecting to MAN and increase the delay (delay is expressed in tens of microseconds)
Do it on both sides location Y / location X and the MAN link will become just a backup link as you desire.
int fas0/0
delay
changing delay is the best way because EIGRP is cumulative on delay while it takes the inverse of the lowest BW on the path
Hope to help
Giuseppe
I agree with Giuseppe in order to accomplish your task at hand is to manipulate EIGRP metrics
I will definitely try this one too.
Thanks!
