RPC PORT ON DMZ
carl_townshend
Hi all, if im having problems with my servers one on the lan and one on the dmz, How can i let rpc requests through the firewall, is there a port number ?
rajbhatt
Level 3
Level 3
Hello Carl,
Please try opening with TCP / UDP 530.
Refer to this link :
http://www.networksorcery.com/enp/protocol/ip/ports00000.htm
Raj
Would I need to open this both ways ?
Hi Carl,
If it is an outbound connection and u have access list on the inside then open only from the inside access list.Is it using tcp or udp ?
Raj
