RPS2300 Power revert back Behavior
s.patsuwan
Hi ,
   I proposed RPS2300 with dual PWR-7500.  I connected two WS-C2960S-48FPD-L to RPS2300.   when i disccounted AC power to both of 2960S switch and Let them use  Power from RPS.   after that, I discounted one of Power source from RPS2300. so Only one 2960S worked but when i put Power Source back to RPS2300.     the 2960S  that was working has been rebooted.    Is it normal behavior for RPS2300 ?
thanks
sompoj
benediktdiehl
Hi sompoj,
have you or anyone of you found a solution for this behavior.
I got the same problem at a customers site.
There are two WS-C2960S-24TS-L connected to a PWR-RPS2300.
During our failover tests we noticed that our WS-C2960S-24TS-L wont switch back to internal power supply automatically.
For some reason the Switch stay in BackingUp mode at the PWR-RPS2300.
At my research for this behavior I found this Cisco document where it says that the WS-C2960S should be able to switch back automatically.
Now I like to ask if there is a known issue or anything have to be configured.
I added output from my tests.
ESW-DUS65
cisco WS-C2960S-24TS-L (PowerPC) processor (revision H0) with 131072K bytes of memory.
Processor board ID
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
56 Gigabit Ethernet interfaces
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       :
Motherboard assembly number     :
Power supply part number        :
Motherboard serial number       :
Power supply serial number      :
Model revision number           :
Motherboard revision number     :
Model number                    : WS-C2960S-24TS-L
Daughterboard assembly number   :
Daughterboard serial number     :
System serial number            :
Top Assembly Part Number        :
Top Assembly Revision Number    :
Version ID                      : V04
CLEI Code Number                :
Daughterboard revision number   :
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
    1 28    WS-C2960S-24TS-L   15.0(2)SE4            C2960S-UNIVERSALK9-M
*    2 28    WS-C2960S-24TS-L   15.0(2)SE4            C2960S-UNIVERSALK9-M
ESW-DUS65#sh env all
FAN is OK
SYSTEM TEMPERATURE is OK
System Temperature Value: 29 Degree Celsius
System Temperature State: GREEN
Yellow Threshold : 50 Degree Celsius
Red Threshold    : 60 Degree Celsius
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1  Built-in                                         Good
2  Built-in                                         Good
SW  Status          RPS Name          RPS Serial#  RPS Port#
1   Active          CiscoRPS            1
2   Active          CiscoRPS            2
RPS Name: CiscoRPS
  State: Active
  PID: PWR-RPS2300
  Serial#:
  Fan: Good
  Temperature: Green
  RPS Power Supply A: Present
    PID             : C3K-PWR-750WAC
    Serial#         :
    System Power    : Good
    PoE Power       : Good
    Watts           : 300/420 (System/PoE)
  RPS Power Supply B: Present
    Serial#         :
    System Power    : Good
    PoE Power       : Good
DCOut  State   Connected  Priority  BackingUp  WillBackup  Portname        SW#
    1  Active  Yes               6  No         Yes         ESW-DUS65         1
    2  Active  Yes               6  No         Yes         ESW-DUS65         2
    3  Active  No                6  No         Yes         <>                -
    4  Active  No                6  No         Yes         <>                -
    5  Active  No                6  No         Yes         <>                -
    6  Active  No                6  No         Yes         <>                -
ESW-DUS05
Processor board ID
Top Assembly Revision Number    : A0
Version ID                      : V04
CLEI Code Number                :
Daughterboard revision number   : A0
*    1 28    WS-C2960S-24TS-L   15.0(2)SE4            C2960S-UNIVERSALK9-M
Mit freundlichen Grüßen,
ESW-DUS05#sh env all
FAN is OK
System Temperature Value: 33 Degree Celsius
1  Built-in                                         Good
2  Built-in                                         Unavail
1   Active          CiscoRPS          1
2   Active          CiscoRPS          2
RPS Name: CiscoRPS
  State: Active
  PID: PWR-RPS2300
  Serial#:
  Fan: Good
  Temperature: Green
    Serial#         :
    System Power    : Good
    PoE Power       : Good
    Serial#         :
    System Power    : Good
    PoE Power       : Good
    1  Active  Yes               6  No         Yes         ESW-DUS05         1
    2  Active  Yes               6  Yes        Yes         ESW-DUS05         2
    5  Standby No                6  No         No          <>                -
