RSP4+
amansoi_5
Dear sir,
I am having RSP4+ installed in Cisco 7507 . I am getting the message "Slave in slot 3 is halted."
Is this message OK. If yes, after my Active RSP goes down , will standby RSP become active automaticall .
regds,
aman
ankbhasi
Hi Aman,
Can you try a command "slave reload" i.e router#slave reload
This will only reload the Slave RSP, and will not effect the Master RSP.
Ankur
Dear Ankur,
Today at night , we will do the same & let u know.
aman
thanks Ankur . resolved my issue...
