RSP720-3C sso_get_reg: ERR sso 0: Log Issue
jhko
hello. I am Ko.
We would like to inquire about the cause of the log below and its effect on the equipment.
06:15:28.849 FW[Mod 07]: sso_get_reg: ERR sso 0: reg 0xB3 value 0x00 rc 0x80
00:33:42.921 FW[Mod 07]: sso_get_reg: ERR sso 0: reg 0xB3 value 0x00 rc 0x80
09:02:05.981 FW[Mod 07]: sso_get_reg: ERR sso 0: reg 0x5F value 0x03 rc 0x80
12:16:40.684 FW[Mod 07]: sso_get_reg: ERR sso 0: reg 0x5F value 0x03 rc 0x80
00:29:55.343 FW[Mod 07]: sso_get_reg: ERR sso 0: reg 0x90 value 0x00 rc 0x80
14:31:27.143 FW[Mod 07]: sso_get_reg: ERR sso 0: reg 0x5F value 0x04 rc 0x80
01:59:14.458 FW[Mod 07]: sso_get_reg: ERR sso 0: reg 0xCE value 0x00 rc 0x80
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRE6, RELEASE SOFTWARE (fc1)
Mod Ports  Card Type                                                     Model
2     24      CEF720 24 port 1000mb  SFP                        WS-X6724-SFP
6     0        4-subslot SPA Interface Processor-400          7600-SIP-400
7     2        Route Switch Processor 720 (Active)              RSP720-3C-GE
9     4        CEF720 4 port 10-Gigabit Ethernet                WS-X6704-10GE
10   4        CEF720 4 port 10-Gigabit Ethernet                WS-X6704-10GE
13   48      CEF720 48 port 10/100/1000mb Ethernet     WS-X6748-GE-TX
I know of a solution that can be solved by rebooting the chassis or module.
However, it is currently impossible to reboot the equipment, and if the log above continues to occur, I wonder what effect it could have if operated without taking any action.
If it is a log that does not affect the service, is it okay to operate it as it is?
Thanks.
Mark Elsen
 - Probably a bug , consider using latest advisory release : https://software.cisco.com/download/home/282188587/type/280805680/release/15.5.3S10 , check if that can help.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thanks for your answer.
Will the service be affected if I continue to operate in a situation where the log occurs?
      - Presumably not   ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
jhko
