Command Line Help
Learnercisco
Level 5
Level 5
Hi Tech People,
I want to clear the Environment counters on the cisco catalyst 9K. Example, I want to clear/delete the history for the following counters, CPU , memory and fan. i could not find the command in the cisco documentation.
show env all ,show process CPU, show process CPU history.
Thanks for your Support.
6 Replies 6
Thanks for the reply,
I found one command, "clear environment counters" but it is not deleting the history.
are SW accept this command ?
yes but no impact.
 the IOS XE is run in many platform, and I think that Cat9K not support this command.
can I know which enviro count you want to clear ?
Leo Laohoo
It is a bug.  The command is accepted but does nothing.
Reboot the switch and the counters will clear.
