RSPAN Pruning Question
Neuromancer
Level 3
Level 3
Is there any way to make RSPAN work when it is being pruned?
wong34539
Level 11
Level 11
you enable VTP and VTP pruning, RSPAN traffic is pruned in the trunks to prevent the unwanted flooding of RSPAN traffic across the network for VLAN-IDs that are lower than 1005. Because RSPAN traffic is carried across a network on an RSPAN VLAN, the original VLAN association of the mirrored packets is lost. Therefore, RSPAN can only support forwarding of traffic from an IDS device onto a single user-specified VLAN
