RSPAN
BigK
Level 5
Level 5
Hello All,
I am struggling to get Rspan configured to capture packet from ipphone over the WAN. the topology is below. Could someone help with the steps to get it done?
Wireshark (pc) --->SWITCH --> ROUTER -->WAN--> ROUTER --> SWITCH -->IPPHONE
Karim
AndreaTornaghi
Level 5
Level 5
Unfortunately you can't do RSPAN over WAN. Which kind of switch are you using?
From my point of view the only way is to use ERSPAN but it is not supported from all switch.
The switch is 3850 - the router is 4431
@AndreaTornaghi
Thanks Andrea,
After some research I found out that I can do Cisco IOS Embedded Packet Capture
since I have 4431 router. I will do some research about it and let you know.
Karim
