RSPAN
sam-lee
I'm sitting at Level 1 and i want to monitor the port at Level 2. Can anyone tell me how to configure RSPAN?
SAM
Hey Sam,
I will say just have a look at this link. This will guide you with sample config on 2950 and will also explain you about RSPAN.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12120ea2/2950scg/swspan.htm#wp1336427
Incase you have any doubt please feel free to come back on the same.
Ankur
*Pls rate all helpfull post
ankbhasi
Hi Sam,
May be we need bit more information. What is level 1 and level 2, is it the floor levels in your organisation?
Also which switches you have in your network on which you want to configure RSPAN.
You can read this link which will guide you to configure RSPAN on 3750 switch.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12235se/scg/swspan.htm#wp1081130
Please come back with your doubts if you have any.
Ankur
Hi Ankur,
Thanks for reply. Yes, Level 1 and Level 2 are referring to the floor levels in my organization. Both levels are using 2950. Can give an example configuration in this situation?
SAM
Hey Sam,
Ankur
