RSTP configuration
senthil.gabriel
Can anyone help me to configure RSTP and port priority in Cisco 6500 Switch ?
Rgds
senthil
Jon Marshall
Hi Senthil
It might help if you could give a few more details as to what you want to achieve. At a basic level the following command will turn on RSTP on a 6500 IOS switch
6500(config)# spanning-tree mode rapid-pvst
And then you can manipulate port costings by going into interface config mode
6500(config-if)# spanning-tree port-priority "number in increments of 16"
But there is a lot more you can setup with STP/RSTP and it all depends on what you are trying to achieve.
Jon
Hi Jon,
Thanks for your reply.
Let me update regarding the above tommorrow.
Rgds
Senthil
