Rsvp understanding and basic configuration
grattmandu03
Since RSVP is not working correctly into my main network, I have tried a basic configuration (as described below) but with no more luck so far.
Here is my basic network configuration with the priority flow coming from 123.22.2.2 and to 123.22.1.2. The non-priority flow will come from 123.22.2.3 to 123.22.1.3.
123.22.1.2   123.22.2.2
 123.22.1.10Router123.22.2.20
123.22.1.3   123.22.2.3
My router configuration is as follow (inspired by this webpage):
version 15.2
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
license udi pid … sn …
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 123.22.1.10 255.255.255.0
 duplex auto
 speed 10
 ip rsvp bandwidth 7500 7500
interface GigabitEthernet0/1
 ip address 123.22.2.20 255.255.255.0
 duplex auto
 speed 10
 ip rsvp bandwidth 1 1
interface GigabitEthernet0/0/0
 no ip address
 shutdown
interface GigabitEthernet0/0/1
 no ip address
 shutdown
interface GigabitEthernet0/0/2
 no ip address
 shutdown
interface GigabitEthernet0/0/3
 no ip address
 shutdown
interface Vlan1
 no ip address
 shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
And after the reservation is done (my router get the PATH and RESV messages) I have the following:
R3#show ip rsvp reservation
ToFromProDPortSPortNext HopI/FFiServBPS
123.22.1.2123.22.2.2UDP3000130000123.22.1.2Gi0/0FFRATE7M
So with this command result, for me the Rsvp reservation seems ok, but when I try to send 6Mbps in UDP for each flow described above, there is no priority at all into the router. The first flow sent gets the priority, so I guess I'm missing some point in order to math the flow with the reservation. I have tried many options but no one worked, so any help or idea will be appreciated.
If you have any questions, fell free to ask.
Sébastien
0 Replies 0
