Running configuration backup to a TFTP Server using kron
thinakraj
hi,
can any one guide me how to configure the automatic running configuration backup to a TFTP server USING kron ..... in the 3560,3548,3550.
My TFTP server ip is 10.91.170.158.
i used this configuration...
#kron policy-list Backup
#do show run | redirecttftp://10.1.1.1/test.cfg
#kron occurrence Backup at 23:00 Sun recurring
#policy-list Backup
to verify the config i give this command ...
3560-24-2F-S1#sh kron sc
Kron Occurrence Schedule
Backup inactive, will run again in 0 days 00:00:12 at 8 :50 on Thu
but is not worked... i don't know what is the problem. even the TFTP is running and i'm able to ping the TFTP from the switch.
Can any one give me a good configuraion ?
Lucien Avramov
Level 10
Level 10
Instead of :
Use :
hi,
Thank you very much it is working :)
Thina.
