rx_long_length_errors on device connected to Nexus 7k - MTU 1500 both sides
WilliamConway
I have an interesting issue that I am struggling to get my head around
I have an EMC Array that has 4 Management ports that are connected to a 7K - we need to upgrade the Array's firmware but one of the pre upgrade checks is for a check on errors on the Nics. We are seeing RX errors - which we have narrowed down to rx_long_length_errors - they are continually increasing (by the same amount on all 4 Nics. Below is a sample of 3 runs 15 seconds apart - while the totals are different you can see the increments are the same on all 4 Nics.
Run 1     X1-SC1 rx_errors: 40333939  Run 2 (run 1 + 2) X1-SC1 rx_errors: 40333941 Run 3 (run 2 + 5) X1-SC1 rx_errors: 40333946
          X1-SC2 rx_errors: 20669588                    X1-SC2 rx_errors: 20669590                   X1-SC2 rx_errors: 20669595
          X2-SC1 rx_errors: 20554720                    X2-SC1 rx_errors: 20554722                   X2-SC1 rx_errors: 20554727
          X2-SC2 rx_errors: 40718384                    X2-SC2 rx_errors: 40718386                   X2-SC2 rx_errors: 40718391
A breakdown of the errors on one Nic shows below but all 4 are similar.
     rx_crc_errors: 0
     rx_missed_errors: 0
     tx_aborted_errors: 0
     tx_carrier_errors: 0
     tx_window_errors: 0
     rx_long_length_errors: 40329872
     rx_short_length_errors: 0
     rx_align_errors: 0
     rx_errors: 40329872
     tx_errors: 0
     rx_length_errors: 40329872
     rx_over_errors: 0
     rx_frame_errors: 0
     rx_fifo_errors: 0
     tx_fifo_errors: 0
     tx_heartbeat_errors: 0
My understanding is that rx_long_length_errors relates to MTU generally - so checked the MTU on both sides - on both sides its 1500.
I am seeing no tx or rx errors on the 7k - but there is a count of historical Jumbo Frames sent - this seems weird and I need to double check but it is possible maybe they are historical - are these stats reset on link up/down or when would they be reset?
Ethernet3/13 is up
admin state is up, Dedicated Interface
  Hardware: 10/100/1000 Ethernet, address: 0026.0b3c.a694 (bia 0026.0b3c.a694)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec <<<<<<<<<<<<<<<<<
  Encapsulation ARPA, medium is broadcast
  Port mode is access
  full-duplex, 1000 Mb/s
  Beacon is turned off
  Auto-Negotiation is turned on
  Input flow-control is off, output flow-control is off
  Auto-mdix is turned on
  Switchport monitor is off
  EtherType is 0x8100
  EEE (efficient-ethernet) : n/a
  Last link flapped 02:38:38
  Last clearing of "show interface" counters 01:16:59
  0 interface resets
  30 seconds input rate 173120 bits/sec, 118 packets/sec
  30 seconds output rate 1446712 bits/sec, 180 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 114.74 Kbps, 17 pps; output rate 1.00 Mbps, 45 pps
  RX
    470117 unicast packets  0 multicast packets  190 broadcast packets
    470307 input packets  76575515 bytes
    0 jumbo packets  0 storm suppression packets
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    617354 unicast packets  14717 multicast packets  59151 broadcast packets
    691222 output packets  670388018 bytes
    2304 jumbo packets <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble  0 output discard
    0 Tx pause
My background is virtualization so apologies if any of the answers here are obvious. My main questions would be.
1) Am I correct in saying rx_long_length_errors are generally MTU - is there anything else that can cause these - has anyone seen similar errors before where MTU was 1500 on both sides.
2) On the show int of the 7k side I see mention of 2304 Jumbo Packets transmitted - the below is in the show int but am unsure if I an equating the time correct
Last link flapped 02:38:38 <- this is likely when we connected the array to this switch (2 hours 38 minutes would be about right)
Last clearing of "show interface" counters 01:16:59 <- is this when the counters are reset (1 hour 16 mins ago - would this include the Jumbo Counter)
3) I assume there is no scenario where a frame of larger than 1500 can be transmitted when mtu is 1500 on both sides - is this assumption correct?
4) Any other general thoughts
0 Replies 0
