Rx power low alarm
Manish Manwal
Cisco 2960 switch show me below log. i recently change its fiber patch cord
%SFF8472-5-THRESHOLD_VIOLATION: Gi1/0/27: Rx power low alarm; Operating value: -27.4 dBm, Threshold value: -24.0 dBm
THANKS
MANISH MANWAL
Leo Laohoo
Bounce the port.
in addition to Leo's post, the problem could also be the other side of the link, what do you have connected to the port ?
Post the output of 'show transceiver gi x/y/z transceiver detail' from both ends...
in same switch
sh int gi1/0/27 transceiver detail
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
mA: milliamperes, dBm: decibels (milliwatts), NA or N/A: not applicable.
++ : high alarm, + : high warning, - : low warning, -- : low alarm.
A2D readouts (if they differ), are reported in parentheses.
The threshold values are calibrated.
High Alarm High Warn Low Warn Low Alarm
Temperature Threshold Threshold Threshold Threshold
Port (Celsius) (Celsius) (Celsius) (Celsius) (Celsius)
Gi1/0/27 31.5 90.0 85.0 -40.0 -45.0
Voltage Threshold Threshold Threshold Threshold
Port (Volts) (Volts) (Volts) (Volts) (Volts)
Gi1/0/27 3.26 3.80 3.70 2.80 2.70
Optical High Alarm High Warn Low Warn Low Alarm
Transmit Power Threshold Threshold Threshold Threshold
Port (dBm) (dBm) (dBm) (dBm) (dBm)
Gi1/0/27 -5.7 -1.0 -2.0 -10.0 -11.0
Receive Power Threshold Threshold Threshold Threshold
Gi1/0/27 -27.4 -- 0.0 -1.0 -23.0 -24.0
and other end switch
sh int te1/0/20 transceiver de
Te1/0/20 33.4 90.0 85.0 -40.0 -45.0
Te1/0/20 3.24 3.80 3.70 2.80 2.70
Te1/0/20 -5.7 -1.0 -1.9 -10.0 -11.0
Te1/0/20 -40.0 0.0 -1.0 -23.0 -23.9
THANKS
MANISH MANWAL
still problem, i have shutdown the port and also change the sfp port, but problem is still there.
THANKS
MANISH MANWAL
